tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
I am getting close to the point where I will be starting my /6 rebuild. When I installed the fan/alternator- I just put it in with the wiring the same as from the previous owner. Before starting, I figured that I probably should check to see if it is correct. I took a picture with a bore scope. The wiring from the PO is different from the reference pictures that I found online. Will this setup work? I would change it to the way the reference pictures show however it is installed and I would prefer not to drop the engine. It is a SEV Motorola alternator.
Sorry about the picture- it's as good as I could get from a bore scope. Attached thumbnail(s) ![]() |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,825 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
I think so. They direct the cooling air over the top of the engine
Lo-Fi Version | Time is now: 1st July 2024 - 03:07 AM |
