Problem with wiring from Relay Board to Coil etc., Wiring Problem from Board to Coil... |
91422.7 |
Apr 6 2015, 12:15 PM
Newbie Group: Members Posts: 36 Joined: 8-October 14 From: Eugene, Oregon Member No.: 17,991 Region Association: Upper MidWest |
Something isn't adding up! I have a 1970 Porsche 914 which I've upgraded with a 2.0L engine out of a 1975 914 along with the 1975 Ignition Wiring Harness. The engine has had the distributor upgraded to an electronic ignition from the original points setup. The two wires coming from the bottom of the distributor (Red goes to Positive terminal on Coil) and (Black goes to negative on Coil). Reference attached picture or diagram I've drawn of the Engine Relay Board, right rear plug in on board! With key on, I'm getting 2 hot wires from the terminals, (One) is the 4th Pin down on left (Solid Black Wire) and the other is the top right pin (Grey with Red Stripe)! The other wires/pins are not hot! Green/Red, Black/Purple, Green Jumper Wire, 2nd Grey/Red Wire, Large Yellow Wire, Black/Red Wire. From diagrams I've pulled from on line, it appears the following wires should go to the following locations from the Engine Relay Board/plug in above mentioned:
* Black/Red Wire goes to (+) Positive on Coil * Black/Purple Wire (Tach Signal Wire) goes to (-) Negative on Coil * Large Yellow Wire goes to Starter * Small Yellow Wire goes to ? * Green/Red Wire goes to Oil Pressure/Sending Unit next to Distributor * Solid Black Wire goes ? * 2 Grey/Red wires go to sending unit on side of transmission ......My question is why are those two wires hot (Solid Black Wire and the One Grey/Red Stripe Wire)? ......Shouldn't instead the Black/Red Wire should be the hot one going to the Coil? ......OR is the problem I have the wrong Wiring Harness and if thats the case why cain't I just change the pin locations on the plug in on the relay? ...Thanks for any help! Attached image(s) |
JeffBowlsby |
Apr 6 2015, 09:02 PM
914 Wiring Harnesses Group: Members Posts: 8,781 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
A couple of things:
914/4 relay boards are all identical, they did not change year to year...the wiring connections changed from the chassis harnesses and ignition harnesses, but the relay boards are not changed. 914;6 relay boards are different from the 914/4 relay boards. What you refer to as Grey/red is Grey brown, they are for the transaxle mounted rear back-up lights. One wire should be hot, the circuit just completes though the switch. What y9ou think is solid black is actually black/red, the red is just very light, dirty or worn off. It connects with pin 7 of the 12 pin connector. You have an LJet ignition harness diagram...that's not correct for a 2.0L. Do you have the 1.8L FI system mounted to the engine also? DJet and LJet hardware and harnesses are not interchangeable. |
SirAndy |
Apr 6 2015, 09:31 PM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
914/4 relay boards are all identical, they did not change year to year...the wiring connections changed from the chassis harnesses and ignition harnesses, but the relay boards are not changed. There are some small differences over the years but you are correct, the boards have the same tracing for all /4 models and by itself are interchangeable. The differences are in what wires connect to what pins on both of the large connectors. Also note that the 85/86 pins for all relays are flipped between early and late cars. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 27th December 2024 - 07:36 AM |
