> Progress thread 74 2.0 to 3.0 6, Time to assemble
Luke M
post Jun 21 2013, 05:56 AM
I figured why not start this thread. The car is a 74 914 2.0 that's been sitting since the early 90's. It was parked outside/in the woods up until my brother purchased it last fall. It didn't look too bad from 20 feet away but when you look closer it gets pretty bad. So, here's the plan... strip the car, fix the rust problems, paint it, add a 5 lug suspension, and convert it to a 3.0 6. Stay tuned for pics of the progress..
(IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif)
Luke M
post Apr 13 2015, 11:10 AM
It's been a busy weekend. We got the lower outer firewall and 75 % of the floor pan welded in place. It took some time making sure the measurements where right. Installed the Tangerine firewall shifter bushing prior to installing the floor pan. Just an FYI if anyone is going to use the RD lower fire wall. You will need parts off your old firewall welded onto the new one. There's an inner shifter bushing plate, e-brake tubes, speedo cable tube, and the brake proportioning valve bracket.
Luke M   Progress thread 74 2.0 to 3.0 6   Jun 21 2013, 05:56 AM
Cupomeat   Looking forward to it! :headbanger:   Jun 21 2013, 06:55 AM
PanelBilly   Hey, that's my plan!   Jun 21 2013, 08:11 AM
Dasnowman   I figured why not start this thread. The car is a...   Jun 21 2013, 04:28 PM
Luke M   I figured why not start this thread. The car is ...   Jun 21 2013, 07:41 PM
mepstein   [quote name='Dasnowman' post='1883388' date='Jun ...   Sep 13 2021, 05:50 PM
Luke M   [quote name='Dasnowman' post='1883388' date='Jun...   Sep 13 2021, 06:41 PM
Luke M   Here's a few pics of the car when it was purch...   Jun 22 2013, 11:44 AM
Luke M   Rust repair in the works.. :sawzall: :smash: :w...   Jun 22 2013, 12:26 PM
Spoke   Good luck and happy welding. Looks like a typical...   Jun 22 2013, 05:40 PM
Luke M   Good luck and happy welding. Looks like a typica...   Jun 22 2013, 06:57 PM
Luke M   Replacing the r/r inner control arm mount was a re...   Jun 24 2013, 07:08 AM
Luke M   Some of the parts that will be used : Original 91...   Jun 25 2013, 07:48 AM
rick 918-S   Nice start! :smash: :sawzall: :welder:   Jun 25 2013, 08:06 AM
Luke M   I'm back to it here. Finally had some time to ...   Sep 21 2013, 08:58 AM
Jamesmichael73   Thats some nice work. I will be following this bui...   Sep 21 2013, 09:32 AM
r_towle   Parked outside in Rochester Ny, the northeast capi...   Sep 21 2013, 10:17 AM
Luke M   Finally got some sheet metal in from a CA parts ca...   Sep 30 2013, 06:36 PM
914forme   Thats some nice work your doing. And don't fe...   Sep 30 2013, 06:48 PM
Luke M   My brother and I finally got a few things done on ...   Nov 24 2013, 08:20 AM
trojanhorsepower   Man that looks familiar. Looks like it is going we...   Nov 24 2013, 09:16 AM
jimkelly   that's a pretty big - and nicely done - repair...   Nov 24 2013, 09:40 AM
Luke M   The door gaps should be ok as I placed the cross b...   Nov 24 2013, 10:04 AM
trojanhorsepower   Luke M, Are you using a stone head or wire or pad...   Nov 24 2013, 10:32 AM
Luke M   [quote name='trojanhorsepower' date='N...   Nov 27 2013, 10:56 AM
maddog   Nice work Luke, I am enjoying the pics and watchin...   Nov 27 2013, 11:20 AM
wndsnd   Well I know what you are dealing with. You are lu...   Nov 27 2013, 11:32 AM
Luke M   The work continues. The right long is done and sta...   Mar 2 2014, 07:49 PM
Luke M   It's been a while since I updated this so here...   Aug 18 2014, 07:31 AM
Luke M   Well now that the cold weather has kinda gone away...   Apr 6 2015, 11:31 AM
nathansnathan   Well now that the cold weather has kinda gone awa...   Apr 6 2015, 12:26 PM
Luke M   Well now that the cold weather has kinda gone aw...   Apr 6 2015, 02:58 PM
Cairo94507   Wow- Nice work. Doing it right is the only way to...   Apr 6 2015, 12:24 PM
Luke M   Wow- Nice work. Doing it right is the only way t...   Apr 6 2015, 03:19 PM
Luke M   It's been a busy weekend. We got the lower out...   Apr 13 2015, 11:10 AM
nathansnathan   That looks awesome. :first: Don't forget the...   Apr 13 2015, 03:35 PM
Luke M   That looks awesome. :first: Don't forget th...   Apr 13 2015, 06:39 PM
trojanhorsepower   Lookin good!   Apr 13 2015, 06:42 PM
914Sixer   Top Notch job !!!   Apr 13 2015, 07:18 PM
Luke M   We got the floor pan/seat mount reinforcement all ...   Apr 19 2015, 08:09 PM
914350   Looking great!!!   Apr 19 2015, 11:40 PM
peteyd   Looks great Luke! How did the cross member fit...   May 15 2015, 02:38 PM
Luke M   Looks great Luke! How did the cross member fi...   May 15 2015, 03:09 PM
3d914   Looks great Luke! How did the cross member f...   May 15 2015, 05:20 PM
Luke M   [quote name='Luke M' post='2187303' date='May 15 ...   May 15 2015, 06:59 PM
Luke M   Back to it here.. :smash: :welder: We got the ...   Jun 4 2015, 09:28 AM
Luke M   My brother and I got a few more things done on his...   Jun 10 2015, 08:49 AM
Luke M   We got the drivers side chassis stiffener, door si...   Jul 1 2015, 07:09 AM
Luke M   Wrapped up the drivers side and moved on to the pa...   Jul 2 2015, 08:12 PM
Luke M   Moving forward on the pass side. Cut out and repla...   Jul 12 2015, 08:26 PM
Luke M   It's been way too hot and muggy here to do any...   Aug 6 2015, 09:04 AM
Luke M   The case and a few other parts came back from the ...   Aug 25 2015, 05:54 AM
Luke M   It's too darn hot 90+ in the garage to do any ...   Sep 5 2015, 06:41 AM
Phoenix914   :popcorn: Looks like you're making good prog...   Sep 5 2015, 07:06 AM
Luke M   I got the head studs installed and set to 135 mm ....   Sep 5 2015, 06:51 PM
Luke M   Got the right rear GT kit installed. Started on th...   Oct 5 2015, 08:50 AM
Luke M   Started building the chassis jig and the brackets ...   Oct 10 2015, 08:42 AM
jmitro   fantastic work; very thorough. Just curious why y...   Oct 10 2015, 09:10 AM
Luke M   fantastic work; very thorough. Just curious why ...   Oct 10 2015, 09:30 AM
trojanhorsepower   Great work guys!   Oct 10 2015, 11:01 AM
Luke M   Slow winter here but we got two transmissions rebu...   Mar 15 2016, 11:26 AM
Luke M   3.0 is almost done. Waiting on cams, rockers then ...   May 19 2018, 10:25 AM
Lucky9146   Man that is a labor of love. You are doing it rig...   May 19 2018, 11:35 AM
mepstein   What kind of induction on the 3.0   May 19 2018, 02:17 PM
Luke M   What kind of induction on the 3.0 Weber 40 IDA...   May 19 2018, 05:20 PM
Justinp71   What kind of induction on the 3.0 Weber 40 ID...   Apr 29 2021, 02:53 PM
Luke M   [quote name='Luke M' post='2610914' date='May 19 ...   Apr 30 2021, 06:40 AM
Luke M   We've been working away slowly on my brothers ...   Jun 25 2019, 06:31 AM
Jamie   We've been working away slowly on my brothers...   Jun 25 2019, 09:27 AM
Luke M   Got a few more things knocked off my brothers 914 ...   May 19 2020, 01:58 PM
Luke M   Worked on the rear trunk pan today. The spot welde...   Mar 13 2021, 05:45 PM
Root_Werks   I really like the spot welder you are using. Yes,...   Mar 16 2021, 05:13 PM
Luke M   I really like the spot welder you are using. Yes...   Mar 16 2021, 06:18 PM
Luke M   My brothers car has reached a huge milestone on We...   Apr 29 2021, 07:33 AM
Shivers   Nice work   Apr 29 2021, 03:16 PM
rgalla9146   Luke.....you are a friggin' glutton. A ve...   Apr 29 2021, 07:24 PM
Luke M   [quote name='rgalla9146' date='Apr 29 ...   Apr 30 2021, 06:31 AM
Luke M   Oh what a PIA it has been getting all of this sand...   May 5 2021, 08:36 AM
Luke M   Well after weeks of cleaning and prepping we final...   Aug 19 2021, 01:53 PM
Cairo94507   Great progress and it is a roller again. :beer2:   Aug 19 2021, 03:01 PM
rgalla9146   Luke your brothers car looks great ! When...   Aug 19 2021, 03:06 PM
Luke M   Luke your brothers car looks great ! Whe...   Aug 19 2021, 07:27 PM
Luke M   We've been working away here.. Got the brakes ...   Sep 11 2021, 06:30 PM
Root_Werks   That's some fast progress! Looking good...   Sep 13 2021, 05:02 PM
Justinp71   Looking good :trophy:   Sep 13 2021, 05:53 PM
Luke M   We've been chipping away at the list here. Got...   Oct 2 2021, 06:46 PM
Luke M   We got the 3.0 on the test stand today. I'm go...   Oct 10 2021, 05:44 PM
Luke M   Fired up the 3.0 tonight... She's a runner and...   Oct 14 2021, 07:29 PM
Krieger   Congratulations! Great feeling isn't it   Oct 14 2021, 10:52 PM
rgalla9146   Go Go Go Luke ! Engine start up before i...   Oct 15 2021, 06:26 AM
Luke M   Go Go Go Luke ! Engine start up before ...   Oct 15 2021, 11:02 AM
Root_Werks   Holy running engines Batman! I applaud your a...   Oct 15 2021, 08:57 AM
Dion   Nice work going on there. Congrats on the engine s...   Oct 15 2021, 11:23 AM
Luke M   Lets see if the video works.. https://youtu.be/Y8...   Oct 16 2021, 09:53 AM
lesorubcheek   Lets see if the video works.. https://youtu.be/Y...   Oct 16 2021, 02:00 PM
Luke M   We had a busy weekend here. Got the wire harness a...   Oct 24 2021, 07:37 PM
Luke M   So I'm stuck with the harness install in the e...   Oct 25 2021, 07:02 PM
rgalla9146   Luke how about this ? Work up the dimension...   Oct 25 2021, 08:10 PM
Mikey914   The fix had been to use a small section of sheet m...   Oct 26 2021, 02:19 AM
Justinp71   Nice build! That will be a blast to drive.   Oct 26 2021, 12:22 PM
43 User(s) are reading this topic (43 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd December 2024 - 09:23 AM
