> Decided to rig up a degree wheel, ARGH!! Valve Train Geometry
DNHunt
post Sep 3 2004, 09:22 PM
914 Wizard? No way. I got too much to learn.
I decided to rig up a degree wheel to use in setting up the valve train. It's just a paper 360 degree disk stuck on my trigger wheel with a pointer off 1 of the studs for the cooling shroud. It should be interesting to see where valves open and close.
Dave
DNHunt
post Sep 4 2004, 09:39 PM
The idea is to get the adjuster parallel to the valve stem at half opening. The intake ended up at .514 and the exhaust ended up at .487.
Here is the intake
DNHunt   Decided to rig up a degree wheel   Sep 3 2004, 09:22 PM
DNHunt   I think it will make it a little easier to replica...   Sep 3 2004, 09:26 PM
d7n7master   SOB!!! I want your engine stand!...   Sep 3 2004, 10:09 PM
Mueller   look'n good Dave :worship: nice degree whe...   Sep 4 2004, 01:22 AM
Tom Perso   Have fun with that!!! Do you have the...   Sep 4 2004, 05:35 AM
DNHunt   Tom Mine are some single springs. I have some spr...   Sep 4 2004, 06:59 AM
Tom Perso   You are all set!!! Good luck... Wh...   Sep 4 2004, 07:44 AM
DNHunt   Chromoly   Sep 4 2004, 08:32 AM
DNHunt   Here's a picture of the trial springs on the v...   Sep 4 2004, 08:34 AM
DNHunt   I made a little stand for the dial indicator that ...   Sep 4 2004, 08:37 AM
DNHunt   I've got a rectangular frame that clamps the i...   Sep 4 2004, 08:40 AM
DNHunt   Well, we managed to get 1 cylinder done. Dad had a...   Sep 4 2004, 09:32 PM
DNHunt   The idea is to get the adjuster parallel to the va...   Sep 4 2004, 09:39 PM
DNHunt   A lot of trial and error. Here as good a shot as I...   Sep 4 2004, 09:46 PM
swood   Dave, how's the vtg going? What adjusters are...   Sep 6 2004, 01:07 PM
Jake Raby   Dave, looking good! I like your tool for the g...   Sep 6 2004, 03:27 PM
DNHunt   The adjusters are swivel feet. The one in the pict...   Sep 6 2004, 03:28 PM
Jake Raby   Looks great Dave... Thats what its suppose to look...   Sep 6 2004, 03:30 PM
DNHunt   Here's Gerry torqueing down the rockers to che...   Sep 6 2004, 03:32 PM
- Lo-Fi Version Time is now: 26th December 2024 - 08:46 PM
