DavidSweden |
Member ![]() ![]() Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia ![]() |
Engine 2.0 76
Rebuilt engine and should start it today. Pulled the plugs and filled oil. Cranked engine to get oil pressure but nothing. Pulled pressure switch and tested with compressed air works fine. Loosened oil filter and cranked again oil ran from filter, tightened filter and tried again.... Nothing. Oil type 20W 50 Need some advice on what to check to find source or problem.... It's just a Pita |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
It's a possibility. If you pull the big piston back out and use a length of rod in place of the spring, you can keep the oil from bypassing. The motor shouldn't run the way though. (IMG:style_emoticons/default/wink.gif)
DavidSweden |
It's a possibility. If you pull the big piston back out and use a length of rod in place of the spring, you can keep the oil from bypassing. The motor shouldn't run the way though. (IMG:style_emoticons/default/wink.gif) Sorry but I don't think this is right, if the pressure is high enough to open the bypass valve then the sender should show oil pressure. Check out the diagram from the WSM Does anyone have any way to test if the pump is pumping oil att pressure? (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1429391927.1.jpg) |
Lo-Fi Version | Time is now: 25th June 2024 - 10:01 PM |
