rtalich |
Member ![]() ![]() Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None ![]() |
Issue just started last night. Just starting out in first gear while slipping the clutch. Once clutch engages at lower RPMs it felt like I was rolling over speed bumps. At faster speeds it seemed fine. Now it is starting to happen more frequent but only at lower RPMs. I have not had a chance to diagnose yet. Anything in particular come to mind?
Thanks Rob |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I am surprised that no-one mentioned that you could have a CV joint coming loose.
Crawl under and check them without jacking the car up. Feel for any loose ends on the axles. They should move along the axis of the axle, but none side to side. Then jack it up and check again. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:06 PM |
