electrical problem, Where did my volts go? |
JimN73 |
Apr 22 2015, 07:42 PM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
I have 12 volts at fuse #7, but only 6 at the rear trunk light and the license plate lights (they're all really dim).
The wiring harness looks old but OK, but I haven't taken a really close look. What could cause that and where can I look? Thanks for your help. |
mr914 |
Apr 22 2015, 08:43 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
(IMG:style_emoticons/default/agree.gif) Corrosion
I personally would start at the fuse holder. Pull the fuse, clean both the holder and the end of the fuse with a wire brush and apply some dielectric grease on both sides. I'd also use the multimeter to check from ground to both sides of the fuse. If that's OK, recheck your volts at the light, if you have 12v your good to go. After that, I would check the back side of the fuse. Disconnect battery and indo the two Phillips screws and lower the panel and inspect. If it's crappy, you may want to go thru the connections one at a time, clean and apply dielectric grease to each of the connectors. In fact, that may be the best way to avoid some electrical gremlins in the future. You never know what a previous owner stashed above the fuse panel. Early 80's I found a bag and a pipe up there (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 07:03 PM |
