Cleaning tunnel tubes... |
SKL1 |
Apr 25 2015, 08:03 PM
Senior Member Group: Members Posts: 1,612 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
In troubleshooting a binding throttle cable, after removing the old cable I was trying to fish the new Terry cable thru the tunnel tube and it kept getting caught up about 2 1/2- 3 feet in towards the front. Could fish a stiff wire through fine but the bigger threaded end would not go past that point. Could also get the old cable end back thru but the new one must be slightly bigger diameter and will NOT go. Looking thru the little holes by the shifter and heater lever (which is removed anyway as I'm not using a heater) I can't really see the tubes anyway so can't see from the front if something is partially blocking it.
I remember helping my son clean the SAI ports on his 993 with an old bicycle brake cable and a power drill and wondered if I fish something like that through it may clean something out left from the restoration and painting. Since I'm not using tubes from the heater cables I thought about using one of those but the flared ends don't fit the throttle cable end that well. Any ideas of what to use on a drill etc to "clean" things out?? I don't want to destroy another cable trying to "force" it through... This throttle linkage project is going to be the end of me... (IMG:style_emoticons/default/headbang.gif) |
Jeff Hail |
Apr 25 2015, 10:33 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Clean the tube out first. Some cables had liners that disintegrate and pieces get stuck in the tube.
If it still wont pass through - Sounds like its hanging up at the bend under the floor crossmember. A trick I learned twenty something years ago.... cut a 1/16 or 1/8 inch off the threads on the pedal end of the cable. Put a nut on it first to chase the threads/ debur after trimming. The crimped section on the usual suspect aftermarket cables is a little fatter and sometimes longer than the factory cables and hangs up at the tube bend not wanting to make the turn. |
ChrisFoley |
Apr 26 2015, 08:03 AM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
... The crimped section on the usual suspect aftermarket cables is a little fatter and sometimes longer than the factory cables and hangs up at the tube bend not wanting to make the turn. (IMG:style_emoticons/default/agree.gif) A good tool for tube cleaning is a 1/8" dia steel welding rod hammered flat on one end and shaped like a spade drill. |
Lo-Fi Version | Time is now: 25th June 2024 - 09:28 PM |
