The joy was short lived...got it working, Oil pressure = 60 but have leak |
DavidSweden |
Apr 26 2015, 11:03 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
Well as the title says is all gone tits up.
I started my rebuilt engine yesterday and broke in the cam, today was supposed to be the first drive. I decided to check the actual oil pressure so I pulled the pressure switch and connected my gauge. There was no pressure even at 2k rpm. The pump is working but there is no pressure. Obviously the oil must be going somewhere, if the high pressure relief plunger is stuck open would this explain what's happening? Appreciate some help |
ConeDodger |
Apr 26 2015, 12:03 PM
Apex killer! Group: Members Posts: 23,757 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Pretty sure you didn't run the cam in with no oil pressure, no oil etc. You would know. It wouldn't even take 20 minutes and you would know... (IMG:style_emoticons/default/blink.gif)
Mechanical gauge problem... |
DavidSweden |
Apr 26 2015, 12:34 PM
Pretty sure you didn't run the cam in with no oil pressure, no oil etc. You would know. It wouldn't even take 20 minutes and you would know... (IMG:style_emoticons/default/blink.gif) Mechanical gauge problem... I checked the gauge with compressed air and it works. I agree that some oil must have been circulating otherwise the engine would seize? If the pump is pumping then the oil must be going somewhere? |
Lo-Fi Version | Time is now: 26th September 2024 - 05:29 PM |
