Shifter springs re-install, is there an easy way ? |
pgollender |
Apr 26 2015, 11:28 PM
Member Group: Members Posts: 193 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
I decided to replace the ball socket on my 1970 shifter . I didn't realize the plate springs were under so much tension. I haven't found a way to put them back.
Any body have an idea ? |
rhodyguy |
Apr 27 2015, 07:22 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Put one end of a spring near a hole. Push one of the pins in as far as you can. The pin should slide about a third of the way in to the spring. Put one of the clips on the pin. This will act as a stop later. The other end of the spring will be resting on the bottom of the base. The pin will keep the spring from jumping out while you wrestle the free end. Take a small metal putty knife, stick it in the free end of the spring and push the free end down into the base. The spring will bow up slightly in the middle. Push/work he pin thru the rest of the spring and hole, then install the other clip. Repeat. Done.
Lo-Fi Version | Time is now: 28th September 2024 - 12:48 PM |
