Oil Temp Gauge, Testing question |
jim_hoyland |
Apr 26 2015, 04:51 PM
Get that VIN ? Group: Members Posts: 9,332 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
If the wire from the oil temp gauge is disconnected from the sender and grounded to the chassis, should this cause the gauge to read a maximum temp ? I assume that as oil gets hotter, resistance is reduced activating the needle in the gauge ?
stugray |
Apr 27 2015, 10:02 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
These temp sensors are Negative Coefficient Thermistors.
The resistance goes down as the temperature goes up. They approach a dead short as the oil temp exceeds 300 degrees (IIRC). So yes, shorting the wire should peg the meter to the Hot side. |
Lo-Fi Version | Time is now: 23rd June 2024 - 12:37 PM |
