Attempt to fix and convert my Bus 2.0 to solid lifters or go with 1.7 motor? |
Mueller |
Apr 28 2015, 01:25 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
I have not worked on my 914 yet, but I was told by the previous owner that "something" is wrong with #3 cylinder, could be valve seats, could be injector or even something with the Megasquirt or a collapsed hydraulic lifter(?)
What I am contemplating is that should I even attempt to fix the 2.0 bus motor or focus on getting a 1.7 installed into the car? Is the 2.0 bus motor that bad hp/torque wise that a stock 1.7 would be a noticeable improvement? If the added cubic centimeters have the advantage what about converting it to solid lifters? Any performance increase or is that mostly for reliability? |
toon1 |
Apr 28 2015, 02:09 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I have not worked on my 914 yet, but I was told by the previous owner that "something" is wrong with #3 cylinder, could be valve seats, could be injector or even something with the Megasquirt or a collapsed hydraulic lifter(?) What I am contemplating is that should I even attempt to fix the 2.0 bus motor or focus on getting a 1.7 installed into the car? Is the 2.0 bus motor that bad hp/torque wise that a stock 1.7 would be a noticeable improvement? If the added cubic centimeters have the advantage what about converting it to solid lifters? Any performance increase or is that mostly for reliability? I'd tear it down and see how bad it is first. you'd know what to do in just a few hours of work. |
Lo-Fi Version | Time is now: 26th September 2024 - 05:24 PM |
