Shifter springs re-install, is there an easy way ? |
pgollender |
Apr 26 2015, 11:28 PM
Member Group: Members Posts: 193 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
I decided to replace the ball socket on my 1970 shifter . I didn't realize the plate springs were under so much tension. I haven't found a way to put them back.
Any body have an idea ? |
rhodyguy |
Apr 28 2015, 11:39 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,117 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Well presented. The lever ball bushing are often overlooked. I hate to be a pain. The contact edge of the detention plate is pretty worn. It should be straight across the contact edge. Is the shift lever grooved at the contact point?
pgollender |
Apr 29 2015, 11:40 PM
....The contact edge of the detention plate is pretty worn. It should be straight across the contact edge. Is the shift lever grooved at the contact point? Rhody- Yes the shifter bar is very worn, look at the 6th frame down. Should I weld this back up and grind it smooth and round ? Also I didn't catch the worn detent plate. Not enough experience. $36 to rid as much slop sounds like a good deal. Not sure what vendor is "the bird"? Pelican parts ? |
Lo-Fi Version | Time is now: 28th June 2024 - 08:46 AM |
