worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,194 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
I have gotten to the point where I need to consider the spring rate. The rear trailing arms are in with true 5 lug hubs, 911 brakes, and some reinforcement. The shocks are bilstein sport. It is a road car with 16 in wheels running no flares so the tire size will be 205.
I have the original springs from the 1972 four cylinder donor. So ladies and gentlemen, please help me with shopping, or not shopping. Thank you! |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
If you use the adjustable spring perches and the smaller diameter springs, you can get springs in 25 lb increments, and they are a whole lot cheaper that the three springs you can buy at the stock diameter.
So, the smaller ones are cheaper, and loads more choices for you over time. |
Lo-Fi Version | Time is now: 27th June 2024 - 06:16 PM |
