The joy was short lived...got it working, Oil pressure = 60 but have leak |
DavidSweden |
Apr 26 2015, 11:03 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
Well as the title says is all gone tits up.
I started my rebuilt engine yesterday and broke in the cam, today was supposed to be the first drive. I decided to check the actual oil pressure so I pulled the pressure switch and connected my gauge. There was no pressure even at 2k rpm. The pump is working but there is no pressure. Obviously the oil must be going somewhere, if the high pressure relief plunger is stuck open would this explain what's happening? Appreciate some help |
stugray |
Apr 30 2015, 01:01 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I get >60 PSI at startup with 20w50.
After 20 minutes of hard driving, it will drop to 20 PSI at (slightly high) idle. And it will drop to 10 PSI (where my warning light turns on) when the idle drops so low that it is about to die. |
Lo-Fi Version | Time is now: 26th September 2024 - 05:27 PM |
