The joy was short lived...got it working, Oil pressure = 60 but have leak |
DavidSweden |
Apr 26 2015, 11:03 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
Well as the title says is all gone tits up.
I started my rebuilt engine yesterday and broke in the cam, today was supposed to be the first drive. I decided to check the actual oil pressure so I pulled the pressure switch and connected my gauge. There was no pressure even at 2k rpm. The pump is working but there is no pressure. Obviously the oil must be going somewhere, if the high pressure relief plunger is stuck open would this explain what's happening? Appreciate some help |
jsaum |
May 1 2015, 08:31 AM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I would drain the oil and check for metal flakes just to make sure you haven't damaged anything before you try starting it again.
Lo-Fi Version | Time is now: 26th September 2024 - 05:26 PM |
