MikeInMunich |
Member ![]() ![]() Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None ![]() |
As recently posted, my car arrived over here in DE (Germany) and to my dismay, the (custom racing) seat, all the way back of course, isn't giving me quite enough leg room for my left leg when using the clutch.
Thanks guys, to those of you who responded to my recent post, (IMG:style_emoticons/default/beerchug.gif) most suggesting that I change the seat, some suggesting the offset adapter to the steering wheel from J.W. Engineering (Rennshift), and naturally the possibility to use a smaller diameter wheel. I am reluctant to change the seat, (IMG:style_emoticons/default/dry.gif) as it 1) matches the passenger seat, 2) matches the interior, 3) was not a cheap custom job (Sophie's Seat Design, Hollywood) and 4) they have the seat heaters from Camp 914! (IMG:style_emoticons/default/hissyfit.gif) So here's my idea / question... (IMG:style_emoticons/default/stirthepot.gif) the first thing I noticed when I got into the car and put my foot on the clutch was that I had to move my foot from far left, where it was, towards the center to get it to the clutch, which was when my thigh then came into contact with the wheel... (IMG:style_emoticons/default/headbang.gif) Has anybody ever done a modification to the pedal assembly to move the clutch pedal outward, to the left? (IMG:style_emoticons/default/idea.gif) It seems to me that this would solve the problem and not be too difficult. (IMG:style_emoticons/default/welder.gif) Is this something that's been done or is perhaps even somewhat common?? (IMG:style_emoticons/default/popcorn[1].gif) As always, thanks! M.i.M. |
struckn |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region ![]() |
See if this helps. I'm 6'2" and the stock wheel was making it difficult to enter and exit the seat, plus it interfered with my legs somewhat.
What I did was replace the original steering wheel with a smaller 13" (350mm) Deep Dish Drift Spec Wheel. It requires a MOM adapter (8002) which is 3" deep. The deep dish off set of the Wheel is also 3" from the hub to the wheel grip which moved the wheel towards the driver. Because the steering column angles upward the wheel is slightly then elevated by moving the wheel closer to the driver. The bottom of my wheel is 16" from the floor and 8" above seat at its forward edge. The top of the clutch peddle to the back of the Wheel is 24". The wheel having been moved closer to the driver also eliminated out stretched arms and is very comfortable. I can get in and out easily plus there is a lot more leg room. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:43 PM |
