tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
Argh- I rebuilt a 2.7l this winter. Everything went very well with no obvious problems. I installed my engine, hooked up all the hoses, filled with oil and hooked up the starter. I had problems with the starter wiring however I finally got them resolved. I was getting 12.6v at the starter. I cranked the starter and the engine turned a couple of times then stopped. When I would crank the starter again, it would just sound like a starter with too low of voltage- the solenoid would shoot out but the starter wouldn't turn. I checked voltage and it was 12.5v. If I look at the fan blade when I crank the starter, I do not see it move even slightly.
What are my options of what could be wrong? I see it as a starter problem or the engine is somehow seized. I do not have the axels hooked up so I cannot see if the engine turns by pushing the car in gear. I have a small window cut in the firewall so I wiggled a 19mm box wrench onto the timing pulley nut. I tried to see if I could turn the engine even slightly and I could not. I couldn't put much force into it however I would have thought it would have moved to some extent. I think I will remove the starter and see if it cranks off of the car. If it functions properly, how can I check to see if the engine is seized without installing the axles. Is there anything common that could cause this issue? I would really prefer not to remove the engine. I am getting somewhat sick of working on it. Any ideas? |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Compression vs Leak Down:
Compression tells you the condition of the rings and valves but does not identify which. Leak down will give you an indication of where the problem is. After pressurizing the cylinder, you listen where the hiss is coming from .... in the exhaust, it is the exhaust valve; in intake, it is the intake valve; and if in the crankcase, it is the rings (or a combination of the above). Pretty simple ..... |
tornik550 |
Compression vs Leak Down: Compression tells you the condition of the rings and valves but does not identify which. Leak down will give you an indication of where the problem is. After pressurizing the cylinder, you listen where the hiss is coming from .... in the exhaust, it is the exhaust valve; in intake, it is the intake valve; and if in the crankcase, it is the rings (or a combination of the above). Pretty simple ..... So in my case, a compression test would be acceptable? The rings are not where the damage is and if there were damage to a valve- it would be on the exhaust valve cause gravity pulled the nut to the bottom of the cylinder. The engine was never run so there shouldn't be any issue with the intake valve. Since my piston rings are new and not seated, what psi range should I be getting for the compression test? |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:22 PM |
