tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
Argh- I rebuilt a 2.7l this winter. Everything went very well with no obvious problems. I installed my engine, hooked up all the hoses, filled with oil and hooked up the starter. I had problems with the starter wiring however I finally got them resolved. I was getting 12.6v at the starter. I cranked the starter and the engine turned a couple of times then stopped. When I would crank the starter again, it would just sound like a starter with too low of voltage- the solenoid would shoot out but the starter wouldn't turn. I checked voltage and it was 12.5v. If I look at the fan blade when I crank the starter, I do not see it move even slightly.
What are my options of what could be wrong? I see it as a starter problem or the engine is somehow seized. I do not have the axels hooked up so I cannot see if the engine turns by pushing the car in gear. I have a small window cut in the firewall so I wiggled a 19mm box wrench onto the timing pulley nut. I tried to see if I could turn the engine even slightly and I could not. I couldn't put much force into it however I would have thought it would have moved to some extent. I think I will remove the starter and see if it cranks off of the car. If it functions properly, how can I check to see if the engine is seized without installing the axles. Is there anything common that could cause this issue? I would really prefer not to remove the engine. I am getting somewhat sick of working on it. Any ideas? |
tornik550 |
Ok I got the nut out of the cylinder. It was oval. There is a major indent where the exhaust valve pressed on it. Here are my compression numbers.
Cyl 4- 160 Cyl 5- 0 Cyl 6- 165 Are these numbers ok? Lol. Just kidding. (IMG:style_emoticons/default/biggrin.gif) Obviously I bent a valve and the heads must come off. Considering that there is most likely a bent valve, damaged seat and damaged compression chamber- can a head like that generally be rebuilt or do I need to start new? Either way is ok, just curious. So if I remember correctly- I will need to remove the engine. Remove the cam tower on the effected side after removing the chain gear..., repair the head, cylinder, piston then reinstall the heads and cam tower. Set the cam timing, adjust the valves and button everything up? Sound right? Kind of annoying but I would rather have this problem now vs later. |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Ok I got the nut out of the cylinder. It was oval. There is a major indent where the exhaust valve pressed on it. Here are my compression numbers. Cyl 4- 160 Cyl 5- 0 Cyl 6- 165 Are these numbers ok? Lol. Just kidding. (IMG:style_emoticons/default/biggrin.gif) Obviously I bent a valve and the heads must come off. Considering that there is most likely a bent valve, damaged seat and damaged compression chamber- can a head like that generally be rebuilt or do I need to start new? Either way is ok, just curious. So if I remember correctly- I will need to remove the engine. Remove the cam tower on the effected side after removing the chain gear..., repair the head, cylinder, piston then reinstall the heads and cam tower. Set the cam timing, adjust the valves and button everything up? Sound right? The heads on a /6 cylinder bank are matched for height. You can have the head fixed and have the machine shop check the other two. If they don't mill the mating surface, you might be OK doing the one head. The rest of it sounds about right. Kind of annoying but I would rather have this problem now vs later. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:06 PM |
