BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 550 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
It turns out that the outside door locks of my new toy don't work. The key inserts too easily, and it won't turn.. It feels like the tumblers are stuck pushed out -- I don't feel the tumblers when I insert or remove the key.
I was able to get the trunk lock working again by squirting penetrating oil into the key hole, but the door locks are resisting that trick. So, it looks like I need to remove the outside door handle assemblies and disassemble and clean the locks. Can the door handles be removed by just removing the nut just inside the rear door edge? Or does the door panel need to be pulled to access more bolts/nuts inside the door? Any other tips or suggestions? |
Cuda911 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California ![]() |
Excellent info., guys.
I see another project in the line-up here. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:02 PM |
