Troubleshooting help needed- /6 engine rebuild won't turn, DAMMIT!!!!! Found the problem |
tornik550 |
May 2 2015, 07:54 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
Argh- I rebuilt a 2.7l this winter. Everything went very well with no obvious problems. I installed my engine, hooked up all the hoses, filled with oil and hooked up the starter. I had problems with the starter wiring however I finally got them resolved. I was getting 12.6v at the starter. I cranked the starter and the engine turned a couple of times then stopped. When I would crank the starter again, it would just sound like a starter with too low of voltage- the solenoid would shoot out but the starter wouldn't turn. I checked voltage and it was 12.5v. If I look at the fan blade when I crank the starter, I do not see it move even slightly.
What are my options of what could be wrong? I see it as a starter problem or the engine is somehow seized. I do not have the axels hooked up so I cannot see if the engine turns by pushing the car in gear. I have a small window cut in the firewall so I wiggled a 19mm box wrench onto the timing pulley nut. I tried to see if I could turn the engine even slightly and I could not. I couldn't put much force into it however I would have thought it would have moved to some extent. I think I will remove the starter and see if it cranks off of the car. If it functions properly, how can I check to see if the engine is seized without installing the axles. Is there anything common that could cause this issue? I would really prefer not to remove the engine. I am getting somewhat sick of working on it. Any ideas? |
tornik550 |
May 7 2015, 08:53 PM
I removed the heads today. There is no damage to the cylinder walls. There is mild damage to the piston crown. Here are some pictures of the cylinder head. Obviously the valve is bent.
Does this look like a repairable head? Obviously it needs a new exhaust valve. What else would you have done? If it appears repairable, who is the best person to send it to for the repairs? Attached thumbnail(s) |
Lo-Fi Version | Time is now: 23rd June 2024 - 02:05 PM |
