tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
Argh- I rebuilt a 2.7l this winter. Everything went very well with no obvious problems. I installed my engine, hooked up all the hoses, filled with oil and hooked up the starter. I had problems with the starter wiring however I finally got them resolved. I was getting 12.6v at the starter. I cranked the starter and the engine turned a couple of times then stopped. When I would crank the starter again, it would just sound like a starter with too low of voltage- the solenoid would shoot out but the starter wouldn't turn. I checked voltage and it was 12.5v. If I look at the fan blade when I crank the starter, I do not see it move even slightly.
What are my options of what could be wrong? I see it as a starter problem or the engine is somehow seized. I do not have the axels hooked up so I cannot see if the engine turns by pushing the car in gear. I have a small window cut in the firewall so I wiggled a 19mm box wrench onto the timing pulley nut. I tried to see if I could turn the engine even slightly and I could not. I couldn't put much force into it however I would have thought it would have moved to some extent. I think I will remove the starter and see if it cranks off of the car. If it functions properly, how can I check to see if the engine is seized without installing the axles. Is there anything common that could cause this issue? I would really prefer not to remove the engine. I am getting somewhat sick of working on it. Any ideas? |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Since the cylinder to head sealing surface is compromised, you need to have him do all 3 heads on the bank so that they are at the same height IF they cut the sealing surface on the one head you are having repaired.
Lo-Fi Version | Time is now: 24th June 2024 - 07:45 AM |
