> Bringing Back The Dead, Restoring/Updating an old school 914-v8 Conversion
LeftCoastErik
post May 14 2015, 09:35 AM
BADPNNY
OK, so I was the *lucky* bastard who ended up with GandolfTheGrey's (previously MichaelT55's) 1972 V8 Car. Specs were as follows.
Engine:
-1962 Buick 215 Aluminum V8
-STD bore, 10.5-1 (stock) comp ratio
-Cyl heads-ported exhaust ports, 3 angle valve grind with hi-retainers-shaft rocker stands shortened .060"-pushrods shortened .125" for geometry correction.
-Camshaft-M-488 custom ground by Shadbolt engineering(Vancouver B.C.) C/W hydraulic lifters
-Spheroidal graphite iron crankshaft, 5 main journal center, thrust mains, .010" under -Rods ground .001"
-New rings
-Hi volume oil pump, Buick V8 filter housing
-Facet electric fuel pump-GM canister filter
-Offenhauser alum intake
-500 cfm Edelbrock carb C/W electric choke
-Buick distributor with Unilite conversion
-Kennedy engineered product #1000 Buick to Porsche adapter
-KEP 9" Flywheel, clutch and throw-out bearing
-Custon h.d. radiator w/ twin Spals
-Toyota Corolla heater
TRANSMISSION:
Custom built V8 side shift trans by Dr. Evil.
Custom ratios
1st gear lock out
Fresh rebuild, newly installed
BODY:
-Rayco FRP front fenders
-Mitcom 916 rear quarter panels
-P.B. Tweeks FRP flared rocker panels
ELECTRICAL:
-Hella H-4 Q.I. headlites
-Eurolens rear tail lites
-Tach converted to 8cyl
-Mechanical oil pressure and water temp
-Alpine CD
-Electric windows
-Updated blade style fuse blocks
SUSPENSION:
-H & H Carrera 19mm adj front sway bar
-Addco 16mm rear sway bar
-140# rear springs (100 stock)
-Stock front torsion bar
-Koni adj front and Koni H.D. rear shock absorbers
-BMW 320i front brake conversion
-Stock Porsche rear calipers
-All four calipers have stainless steel liners and completely rebuilt.
-Adj proportioning valve
-19mm 911 master cylinder
-All rotors have been crossdrilled
-All flex lines are braided stainless steel
-Pagio performance brake pads, all four wheels
-Carrol Shelby Mini-Europa wheels 7/15 front 8.5/15 rear
-Custom roll bar with rear chassis supportsAttached Image
LeftCoastErik
post May 14 2015, 09:59 AM
BADPNNY
I yanked the rockers and my heart started to sink a little. I NEVER buy old cars without looking at them first...I made an exception in this case and it bit me in the ass. In Gandolf (steven)s defense, he did nothing except the mechanicals on the car when he had it and barely drove it. BUT, the rust is pretty ugly.
Hell hole is good (probably because the car was converted in 1984 and the battery moved to the front trunk). BUT the long is hammered, as is the passenger jack point. The inner long is surprisingly OK. Front of passenger footwell is separating. Pedal box has some rust, drivers inner fender and master area have been repaired from an accident, I imagine. Drivers tub is pushed up some, but not wrinkled. Passenger rocker area was poorly repaired with fiberglass and was holding water. I found standing water under the floor mats and seats. Passenger quarter is separating from the sail panel (fixable)
Also, the front fenders are molded into the cowl, so they have to be cut out. I have QRS GT flares and front end to install in the car, so that is on the list also.
Its a good running car with some nice parts, but its kind of a mess compared to the 73 I just restored.
Wiring was a mess, power windows only sort of worked. Extra gauges were old school and one of them was arcing on the subwoofer installation..Arggg...
Anyway, teardown happened in one night, so today I get started on installing Brad's Long kit, the gt chassis reinforcement and a bunch of patch panels.Attached Image Attached ImageAttached Image
LeftCoastErik   Bringing Back The Dead   May 14 2015, 09:35 AM
LeftCoastErik   Looks like a good car, right? Gandolf had recentl...   May 14 2015, 09:41 AM
LeftCoastErik   I yanked the rockers and my heart started to sink ...   May 14 2015, 09:59 AM
LeftCoastErik   More pics   May 14 2015, 10:03 AM
LeftCoastErik   and some more No problem zip tying the battery ca...   May 14 2015, 10:05 AM
LeftCoastErik   So, yeah...going to be doing a lot of this :welde...   May 14 2015, 10:08 AM
rhodyguy   Bummer   May 14 2015, 10:15 AM
rjames   Bummer indeed. At least it looks like you have th...   May 14 2015, 10:44 AM
Mueller   Ouch....using the speaker to pick up the metal scr...   May 14 2015, 10:55 AM
matthepcat   Bummer about the rust. The car is going to look ...   May 14 2015, 11:50 AM
LeftCoastErik   Yeah, definitely a bummer, but stuff happens. My ...   May 14 2015, 12:03 PM
whitetwinturbo   .........and I had this one on the "watch...   May 14 2015, 08:51 PM
r_towle   Dude, don't lose the magic speaker that goes b...   May 14 2015, 09:01 PM
LeftCoastErik   Day 2 saw the removal of the rear right suspension...   May 15 2015, 10:13 AM
LeftCoastErik   Holes were added so I could spray Ospho in there a...   May 15 2015, 10:15 AM
BillC   What breed/kind of dog is that? He (she?) look...   May 19 2015, 07:34 PM
RobW   Super cool. Dig the pup too! Let me know if yo...   May 15 2015, 11:05 AM
LeftCoastErik   Rob, I may just take those off your hands. Bring ...   May 15 2015, 11:31 AM
tomrev   I too was following the car on ebay; not to buy, a...   May 15 2015, 02:48 PM
LeftCoastErik   Days 3-5 were pretty exciting also.. Got the longs...   May 19 2015, 02:26 PM
LeftCoastErik   More pics. New 17" Fachs and RE71R tires wa...   May 19 2015, 02:29 PM
Mueller   Those 17" Fuchs are nice! Nice meeting y...   May 19 2015, 05:03 PM
LeftCoastErik   Thanks! You too man!   May 19 2015, 05:26 PM
Chris H.   Nice work! The Brad Mayeur kit should stiffen...   May 19 2015, 05:50 PM
LeftCoastErik   These right here. I know the Brad kit made a nigh...   May 19 2015, 05:55 PM
Chris H.   Nice! Mine are very similar. White during th...   May 19 2015, 06:45 PM
LeftCoastErik   Cool. They have great reviews and the gps speedo m...   May 19 2015, 07:01 PM
LeftCoastErik   Probably related! He came from big dog rescue ...   May 19 2015, 08:06 PM
a914guy   Keep up the pace Erik. Nice work and ditto on the...   May 19 2015, 09:06 PM
LeftCoastErik   No updates for a while, sorry. I did get the inter...   May 27 2015, 10:34 AM
arkitect   Erik, Cool work bringing the longs back in shape, ...   May 28 2015, 06:13 AM
LeftCoastErik   Thanks Dave. I am actually disappointed in those w...   May 28 2015, 11:13 AM
LeftCoastErik   I think I am going to rename the car the FML914..E...   May 29 2015, 10:37 AM
Chris H.   YIKES! Imagine if the insulation rubbed thr...   May 29 2015, 11:04 AM
LeftCoastErik   Yeah, when I got the truck of the transport and pa...   May 29 2015, 11:24 AM
matthepcat   While your at it, you should just drop the 901 and...   May 29 2015, 06:47 PM
LeftCoastErik   Yesterday I got the rear inner fenders cleaned and...   May 30 2015, 08:20 AM
arkitect   Yesterday I got the rear inner fenders cleaned an...   Jun 5 2015, 04:53 AM
LeftCoastErik   More   May 30 2015, 08:20 AM
LeftCoastErik   Trailing arm   May 30 2015, 08:21 AM
LeftCoastErik   More pics from the weekend. Got the entire GT rei...   Jun 1 2015, 10:33 AM
whitetwinturbo   Had this on "watch" too..........and I...   Jun 1 2015, 10:25 PM
whitetwinturbo   Is the white GT front fender replacement fiberglas...   Jun 1 2015, 10:34 PM
LeftCoastErik   Yes. From QRS   Jun 1 2015, 10:36 PM
Andyrew   My my my thats a lot of welding!!   Jun 1 2015, 10:48 PM
LeftCoastErik   Yeah. They seem like small parts..but it adds up. ...   Jun 1 2015, 11:05 PM
whitetwinturbo   Final color stays black?   Jun 2 2015, 10:44 AM
LeftCoastErik   Probably. It was originally irish green, which I ...   Jun 2 2015, 11:36 AM
matthepcat   Sweet about the EFI. I want to hear how it goes, a...   Jun 2 2015, 06:52 PM
LeftCoastErik   I decided that the old, hammered relay board and a...   Jun 4 2015, 01:12 PM
whitetwinturbo   I decided that the old, hammered relay board and ...   Jun 4 2015, 04:26 PM
Chris H.   Wow, the right guy got this car for sure... it...   Jun 4 2015, 06:08 PM
LeftCoastErik   I got the dash top pulled to have Tri Valley Auto ...   Jun 5 2015, 10:25 AM
LeftCoastErik   As for color...its either black or maaayyyybeeee.....   Jun 5 2015, 10:28 AM
whitetwinturbo   As for color...its either black or maaayyyybeeee....   Jun 5 2015, 11:05 AM
whitetwinturbo   Eric, How is the WHOLE fiberglass front fender att...   Jun 5 2015, 11:03 AM
LeftCoastErik   Good question...I haven't gotten that far yet....   Jun 5 2015, 11:06 AM
LeftCoastErik   That coppertone is cool! I think the flat clea...   Jun 5 2015, 11:08 AM
whitetwinturbo   That coppertone is cool! I think the flat cle...   Jun 5 2015, 12:14 PM
howlndog   Regarding colour... have you ever played around wi...   Jun 5 2015, 11:41 AM
LeftCoastErik   Holy crap!! That is awesome! ! Tha...   Jun 5 2015, 12:12 PM
LeftCoastErik   I took a stab at it... I will be making a custom m...   Jun 5 2015, 04:03 PM
craig downs   I love the color on that truck. That would look gr...   Jun 5 2015, 04:39 PM
whitetwinturbo   WOW..........Yes on that color! It will be 1 ...   Jun 5 2015, 04:39 PM
matthepcat   I say no to 911 reflector, but he'll yes to th...   Jun 5 2015, 06:08 PM
whitetwinturbo   I say no to 911 reflector, but he'll yes to t...   Jun 5 2015, 09:00 PM
LeftCoastErik   I got a lot done this weekend. I also cursed a lo...   Jun 8 2015, 02:59 PM
LeftCoastErik   Here are some pics of the "Not-so-significant...   Jun 8 2015, 03:02 PM
LeftCoastErik   and the fixing..   Jun 8 2015, 03:04 PM
LeftCoastErik   last pic for now...More to follow after I get the ...   Jun 8 2015, 03:05 PM
whitetwinturbo   Like Pres Bill Clinton said: ....what's you d...   Jun 8 2015, 04:07 PM
matthepcat   :barf: I guess the next one will be a west coast...   Jun 8 2015, 05:10 PM
LeftCoastErik   Hence the #fml914   Jun 8 2015, 05:19 PM
LeftCoastErik   On a positive note..I just came home to these beau...   Jun 8 2015, 05:38 PM
matthepcat   Nice! My GPS speed hut gauge took like 3 weeks...   Jun 8 2015, 05:48 PM
LeftCoastErik   Iirc they are 4" and the tach is 4.5   Jun 8 2015, 06:06 PM
Andyrew   Those are nice!   Jun 8 2015, 06:20 PM
LeftCoastErik   The #FML914 continues to live up to its name..I fi...   Jun 10 2015, 11:12 AM
whitetwinturbo   When will the PO "insignificant" rust en...   Jun 10 2015, 03:17 PM
TargaToy   Looking good, Erik! Do you like your magnetic...   Jun 10 2015, 04:00 PM
LeftCoastErik   Thanks!. Yeah I swear by it   Jun 10 2015, 04:06 PM
whitetwinturbo   Erik, Here's more another shade of "coppe...   Jun 12 2015, 10:13 AM
LeftCoastErik   Looks like the candy brown on my 55 buick kustom. ...   Jun 12 2015, 11:17 AM
whitetwinturbo   Nice paint job!   Jun 12 2015, 11:41 AM
LeftCoastErik   Thanks! It'd be nice if pics would post co...   Jun 12 2015, 11:48 AM
LeftCoastErik   I had a busy weekend of exciting rust bucket work....   Jun 15 2015, 10:36 AM
LeftCoastErik   more   Jun 15 2015, 10:38 AM
LeftCoastErik   I then moved on to the front of the car and discov...   Jun 15 2015, 10:47 AM
LeftCoastErik   Here's the drivers side...some of the spot wel...   Jun 15 2015, 10:49 AM
LeftCoastErik   I got everything seam welded up and then made new ...   Jun 15 2015, 11:27 AM
LeftCoastErik   I still have some work to do in the exposed corner...   Jun 15 2015, 11:36 AM
whitetwinturbo   Eric, you are the "welding MAN"! :w...   Jun 15 2015, 11:36 AM
LeftCoastErik   I am on my second big bottle of gas, and this spoo...   Jun 15 2015, 11:37 AM
LeftCoastErik   I decided to take another welding brake Saturday a...   Jun 15 2015, 11:39 AM
whitetwinturbo   :wub:   Jun 15 2015, 11:42 AM
LeftCoastErik   Thanks, I figured that out, but its a pain in the ...   Jun 15 2015, 11:42 AM
LeftCoastErik   The past few days have been eventful. Got the fue...   Jun 18 2015, 12:27 PM
whitetwinturbo   B:) Love all the new "jewerly"......have...   Jun 18 2015, 02:22 PM
howlndog   yes, have a good vacation.... but more importantly...   Jun 18 2015, 02:26 PM
3 Pages V  1 2 3 >
16 User(s) are reading this topic (16 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 10:03 PM
