door handle problem, spins and spins |
jacksun |
May 16 2015, 11:05 AM
Member Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest |
Hi,
trying to remove the door handles and the nut just spins.. so does the threaded stud.. A is where I scrapped away some of the rubber seal and the threaded stud is visable and it turns when the nut is wrenched. B is the nut that is scarred from the vise grips... wrench would just turn the nut and the threaded stud C is the nut and stud in question.... a snip from an image of some one else's. the car was painted with the handles on by some one previously. I would think that the threaded stud would just come out when wrenching the nut?? any ideas??? please... thanks randal |
TheCabinetmaker |
May 16 2015, 12:21 PM
I drive my car everyday Group: Members Posts: 8,325 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Remove the door panel then remove the 5mm Allen screw that holds the front of the handle from the inside, then you can get a pair of vise grips on what is left of the stud.
Lo-Fi Version | Time is now: 27th December 2024 - 05:01 AM |
