door handle problem, spins and spins |
jacksun |
May 16 2015, 11:05 AM
Member Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest |
Hi,
trying to remove the door handles and the nut just spins.. so does the threaded stud.. A is where I scrapped away some of the rubber seal and the threaded stud is visable and it turns when the nut is wrenched. B is the nut that is scarred from the vise grips... wrench would just turn the nut and the threaded stud C is the nut and stud in question.... a snip from an image of some one else's. the car was painted with the handles on by some one previously. I would think that the threaded stud would just come out when wrenching the nut?? any ideas??? please... thanks randal |
screenguy914 |
May 16 2015, 01:19 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Try inserting a pry bar or equiv. in space A, between the handle assy and door panel, then apply prying force while rotating the nut. Hopefully, the stud should back out from the handle assy.
If you're patient and careful, you may be able to save the handle. Inspect to see if there's enough meat to repair with a new thread insert or equiv. Sherwood |
URY914 |
May 17 2015, 03:33 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 124,254 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Try inserting a pry bar or equiv. in space A, between the handle assy and door panel, then apply prying force while rotating the nut. Hopefully, the stud should back out from the handle assy. If you're patient and careful, you may be able to save the handle. Inspect to see if there's enough meat to repair with a new thread insert or equiv. Sherwood You'll break the mounting tab doing this. But feel free to do it and send it to me to be repaired. I could use some cash. |
Lo-Fi Version | Time is now: 27th December 2024 - 05:28 AM |
