The joy was short lived...got it working, Oil pressure = 60 but have leak |
DavidSweden |
Apr 26 2015, 11:03 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
Well as the title says is all gone tits up.
I started my rebuilt engine yesterday and broke in the cam, today was supposed to be the first drive. I decided to check the actual oil pressure so I pulled the pressure switch and connected my gauge. There was no pressure even at 2k rpm. The pump is working but there is no pressure. Obviously the oil must be going somewhere, if the high pressure relief plunger is stuck open would this explain what's happening? Appreciate some help |
stugray |
May 4 2015, 01:29 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
You can inspect the cam without splitting the case halves.
That ridge in your picture is the topic of many threads. The Tangerine racing pressure relief valve was specifically designed to avoid that problem. Others have honed it down to eliminate sticking |
DavidSweden |
May 4 2015, 01:43 PM
You can inspect the cam without splitting the case halves. That ridge in your picture is the topic of many threads. The Tangerine racing pressure relief valve was specifically designed to avoid that problem. Others have honed it down to eliminate sticking Stugray I just sent a mail to Chris and ordered the Tangerine racing pressure relief valve, thanks for pointing me in the right direction. Is there much point in inspecting the cam I guess I will need to split the case to change my bearings....Is there a chance there not toast? |
DavidSweden |
May 18 2015, 10:13 AM
You can inspect the cam without splitting the case halves. That ridge in your picture is the topic of many threads. The Tangerine racing pressure relief valve was specifically designed to avoid that problem. Others have honed it down to eliminate sticking Stugray I just sent a mail to Chris and ordered the Tangerine racing pressure relief valve, thanks for pointing me in the right direction. Is there much point in inspecting the cam I guess I will need to split the case to change my bearings....Is there a chance there not toast? Well after dropping the engine I found the source of my oil pressure problem, I now have oil pressure 60 psi on cold idle going to 20 when warm, (have not installed Tangerine relief valve yet). However I now have a steady oil drip coming from between the gearbox and engine, I guess it must be the flywheel oil seal? Question; Is it easy to remove the gearbox without dropping the engine to get at the seal and is there anything to look out for? Thanks |
Lo-Fi Version | Time is now: 26th September 2024 - 05:29 PM |
