> starting issues, having problems running
pose
post Sep 7 2004, 06:22 PM
hi,
im a newbie so please excuse the beginner's questions.
I have a 1975 1.8L L-jet. Currently the car will start, but not idle at all. I checked all the vaccuum lines in back and cant find anything wrong with them. The car reads as having between and quater and half of a tank of guess, which i put in.
I just replaced the battery and i can hear the feul pump humming when I turn the car on.
I am baffeled as to what the heck is going on, any help would be appreciated.
Thanks.
Trekkor
post Sep 7 2004, 11:13 PM
I do things...
I had the same set-up years ago 75 1.8 l-jet. Didn't like it.
Always had problems. Went through everything. Ran good, sometimes. Wouldn't pass smog. Sold it.
Anyway, check the position of the flapper in the air flow meter ( potentiometer? name? ). If it stays shut while cranking it will start on cold start injector only and then die.
Make sure that flapper is able to move freely. There is a plastic lid on top of the AFM that lets you fake the brain out if you open it up. You may need an assistant to help you.
I have a spare one here, if you want to try it. Brain, too.
KT
pose   starting issues   Sep 7 2004, 06:22 PM
Brad Roberts   Welcome :clap: I dont know a damn thing about th...   Sep 7 2004, 07:40 PM
SirAndy   CHT? Vaccuum leak? TPS? i'm just guessing he...   Sep 7 2004, 07:50 PM
Brad Roberts   Yep. one vacuum line off and they die pretty easy....   Sep 7 2004, 08:10 PM
pose   any advice on a good way to check for vaccuum leak...   Sep 7 2004, 08:21 PM
  Sep 7 2004, 08:25 PM
Brad Roberts   Very important that the oil cap be 100% sealed. If...   Sep 7 2004, 08:27 PM
trekkor   I had the same set-up years ago 75 1.8 l-jet. Didn...   Sep 7 2004, 11:13 PM
pose   spare assistant and brain? do i understand you cor...   Sep 8 2004, 04:17 PM
trekkor
  Sep 8 2004, 05:11 PM
- Lo-Fi Version Time is now: 22nd December 2024 - 11:49 AM
