Nemisus |
Member ![]() ![]() Group: Members Posts: 82 Joined: 1-October 11 From: North Bay CA Member No.: 13,631 Region Association: Northern California ![]() |
So I am stumped. When I took delivery of my newly acquired 74 914 the car would start up just fine with a jump box.
I went out and bought a new battery and now I have no spark... at lest from I can tell doing the simple spark tests I have done. I just did an Ohms test on my Ignition coil and here is what I got Primary: 1.4 Secondary: 10.41 Per the Pelican Technical Article I should see readings like this: primary coil winding's should give a reading of 0.3-0.6 ohms. Secondary coils should be near 600 ohms. If I understand my results I am significantly higher than where I should be? But does that mean my coil is is the cause of no spark. The only thing I changed was a busted fuel line and put in a new battery... Now the car will not start. Any ideas on where else to look? Thanks in advance Cheers Nem |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Notes from my plugs research:
NGK BP6ES voted best plug for 914 (per Cap'n Krusty): http://www.914world.com/bbs2/index.php?showtopic=217463 BOSCH W7CC for carbs (then adjust heat range based on particular engine). Reputable local 914 racer says you can use the Bosch 4 prong plugs #4417 but I havent tried them yet. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:15 AM |
