tach testing, two bad tachs? |
Alphaogre |
May 30 2015, 05:27 PM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
I am in the process of trying to get my tach working. I baught a used one under the assumption that mine had an internal issue. The second used one I picked up also is not working when I hooked it all up.
I read on an old pelican forum that you can test the tach by connecting it outside of the wiering harness by connecting the + to Power the - to ground and the blk/purple plug directly to the - on the coil. Would this infact work? What if you dont have the original coil, but a replacement one? would that matter? I connected the + of the tach to the + on the batt, then the - of the tach to the - on the batt. I then connected the blk/purple connector directly to the - on the coil. Am I doing somethint wrong here? Are these VDO Tach known for going out? Any help would be great! This is all on a 1970 914 4 1.7 |
72wrxporsche914 |
May 30 2015, 11:38 PM
Member Group: Members Posts: 52 Joined: 3-May 15 From: Fresno ca Member No.: 18,697 Region Association: None |
The tack also needs 12 volts . Check your power with the key on .
Lo-Fi Version | Time is now: 31st October 2024 - 08:23 PM |
