thieuster |
Member ![]() ![]() Group: Members Posts: 447 Joined: 31-January 15 From: 275 mls NW from Stuttgart. Member No.: 18,384 Region Association: Europe ![]() |
My car came with three fixed seat belts. But I don't trust 42 y/old seat belts with unknown history. So I want to change over to retractable seat belts. My MY 73 model already has the bolt holes behind the rear padding where the reel should be placed.
I think it's not wise searching for NOS & period correct seat belts. More modern aftermarkets items are my first port of call. But before I hand over the cash, what are the do's and don'ts. As said: please educate me! Menno |
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,926 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
If you install an aftermarket seatbelt keep in mind that the mounting bolts may differ in length from stock (even if the belt is marketed as a 914 seat belt). Specifically, when mounting at the tunnel on driver's side it's common that the longer bolt will interfere with movement of the shift rod in the tunnel and you'll wonder why you can't find 1st, reverse, or another gear. It is easily fixed, but it can frustrate you if you're not smart enough to immediately realize what caused the shifting issue.
And yes, ask me how I know. That's all I got. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:00 AM |
