Buying 73 been sitting outside 20 years |
LukeD |
Jun 9 2015, 09:21 AM
Member Group: Members Posts: 254 Joined: 14-November 04 From: Atascadero, CA Member No.: 3,117 Region Association: None |
Jumping back into the 914 scene, got a lead on a 1 owner signal orange 73 - 1.7 that has been sitting outside in Central Valley California uncovered for about 20 years ("ran when parked"). Went and looked at the car yesterday, little surface rust on the battery tray, no visible rust under it, passenger long has no visible rust. Seems complete but obviously weather beaten. He only wants a couple hundred dollars so I'm not going to pass it up. Looking for a checklist of absolute musts to attempt to get the car started
Must; - Remove fuel tank, clean and check for rust - replace all fuel lines and filter - replace injector seals - soak injectors? in what? - change oil with what type? - clean all contact on relay board and fuse panel What else? Anyone point me to some threads of those that have done this before? I've searched for "resurrect" "revive" "sitting outside" no good hits. Thanks! -Luke |
Heeltoe914 |
Jun 9 2015, 08:55 PM
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
In my opinion I would pour Marvel Mystery oil down the spark plug hole and or PB Blaster sprayed into each cylinder to brake the rings away from cylinders. Then take an air lines and put a little air to move the oil around wait two days and do it again. After about a week hand roll the engine over or put the car in 2nd see if you can roil it gently. Now drain the oil and ad new oil ( 30 weight ) put the injection together start it and see what you got??? It will smoke allot for about 10 minutes, keep the RPM way down, And don't forget to adjust the valves before starting the motor. Good Luck.
I just did this for a 73 914 2.0 that was sitting for 33 years I drove the car within 5 hours of getting it home with a single carb. It ran so good I did not rebuild it I just pulled it & resealed everything returned it back to F.I. and its been great. |
Phoenix914 |
Jun 10 2015, 10:55 PM
Member Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States |
Dude. Please post one more time. 999 is killin' me.
In my opinion I would pour Marvel Mystery oil down the spark plug hole and or PB Blaster sprayed into each cylinder to brake the rings away from cylinders. Then take an air lines and put a little air to move the oil around wait two days and do it again. After about a week hand roll the engine over or put the car in 2nd see if you can roil it gently. Now drain the oil and ad new oil ( 30 weight ) put the injection together start it and see what you got??? It will smoke allot for about 10 minutes, keep the RPM way down, And don't forget to adjust the valves before starting the motor. Good Luck. I just did this for a 73 914 2.0 that was sitting for 33 years I drove the car within 5 hours of getting it home with a single carb. It ran so good I did not rebuild it I just pulled it & resealed everything returned it back to F.I. and its been great. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:21 PM |
