Ferg |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None ![]() ![]() |
So two things I need to find out to finish this install...
1. What is a good switched 12v power source for the red wire? One that is close by the distributor and coil? 2. I took my bosh coil off, to test ohms and only got .6, the instructions say i need 1.5 ohms so I think i need a new coil. what kind? Oil or epoxy, Is pertronix flamethrower coil the way to go? Thanks Ferg. |
Ferg |
I am sorta following you, but very electrical stupid, so bear with me... when I tested the coil I took it completely off the car, and tested with no wires whatsoever hooked to it, so the resistor (if i have one) should have no effect on my reading of .6 right???
Ferg. |
Lo-Fi Version | Time is now: 25th June 2024 - 01:10 AM |
