temp sensor |
temp sensor |
last337 |
Jun 29 2015, 06:58 AM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
Does anyone know where the temp sensor wire connects to? I cant seem to trace it down in the wiring chart. The hard coating came off but I still have the underlying wire with the spade connection at the end just cant recall where it connects.
last337 |
Jun 29 2015, 09:59 AM
That crush washer on sender, can I get just that washer or do I need the entire replacement sender?
type47 |
Jun 29 2015, 10:09 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
... can I get just that washer ... I did a brief look at the PET but couldn't find a part number for the crush washer or the temp sender for the taco. If it were me, I'd measure the ID and OD of the crush washer you have and match it up with what's available at McMaster-Carr. While you're at it, match up the sealing washers for the taco bolts at M-C too. Cut a gasket too. |
last337 |
Jun 29 2015, 10:13 AM
Lo-Fi Version | Time is now: 26th June 2024 - 07:18 AM |
