> Any successful radiator in engine compartment conversions?, Or other than front trunk installs?
Mueller
post Dec 5 2014, 01:05 PM
914 Freak!
I know this had been tried 7+ years ago, I was wondering if since then has anyone done a watercooled conversion and not put the radiator in the front trunk?
Chris914n6
post Jun 29 2015, 02:39 PM
Jackstands are my life.
Looking at racing rads for toyota celica/mr2/spyder ran across racing rads for motorcycles that were not curved, if someone was considering doing multiple small rads now is a good time to hit ebay.
Mueller   Any successful radiator in engine compartment conversions?   Dec 5 2014, 01:05 PM
76-914   Robert (rotary914) has. However, there is lots of ...   Dec 5 2014, 02:40 PM
shoguneagle   Master Mueller's "engineering mind" ...   Dec 5 2014, 02:57 PM
Mueller   Master Mueller's "engineering mind...   Dec 5 2014, 03:03 PM
effutuo101   My 2.5 suby turbo goes up to get the final bracket...   Dec 5 2014, 03:21 PM
d914   jeep cherokee rad is like 10 x 36 and they make al...   Dec 5 2014, 04:42 PM
GeorgeRud   I always thought that using two small radiators in...   Dec 5 2014, 04:54 PM
mepstein   I would love for the radiator to work in the engin...   Dec 5 2014, 07:45 PM
bulitt   I would love for the radiator to work in the engi...   Dec 9 2014, 02:28 AM
mepstein   I would love for the radiator to work in the eng...   Dec 9 2014, 05:32 AM
Chris914n6   ^^ Countach and Diablo. GT engine lid and some sc...   Dec 5 2014, 08:00 PM
DBCooper   Uh huh, that's the theory....   Dec 5 2014, 09:29 PM
effutuo101   So, running an air cooled big 6 gets enough air. W...   Dec 5 2014, 09:34 PM
Mueller   So, running an air cooled big 6 gets enough air. ...   Dec 5 2014, 09:49 PM
SirAndy   So, running an air cooled big 6 gets enough air. W...   Dec 6 2014, 11:36 PM
904svo   [quote name='Mueller' post='2118709' date='Dec 5 ...   Dec 7 2014, 09:57 PM
SirAndy   Here is my rear mounted radiator in my 904 kit car...   Dec 7 2014, 10:04 PM
904svo   Here is my rear mounted radiator in my 904 kit ca...   Dec 7 2014, 10:16 PM
Brian Mifsud   [quote name='Mueller' post='2118709' date='Dec 5 ...   Jun 26 2015, 12:23 PM
Mueller   Adding to this.. the 911 engine uses Mechanical...   Jun 26 2015, 04:37 PM
Brian Mifsud   hmmm, maybe we are looking at this the wrong wa...   Jun 29 2015, 10:49 AM
SirAndy   Years ago, at an autocross, I had to laugh at the...   Jun 29 2015, 09:14 PM
Brian Mifsud   Years ago, at an autocross, I had to laugh at th...   Jun 30 2015, 10:42 AM
Dave_Darling   ...taking furnace ducting, and running it straight...   Jun 30 2015, 09:02 AM
SirAndy   water is a more efficient medium than air so And ...   Dec 6 2014, 11:41 PM
worn   water is a more efficient medium than air so And...   Jun 26 2015, 07:11 PM
Dave_Darling   It's also been done with an N/A Scooby motor. ...   Dec 5 2014, 09:41 PM
thelogo   I always though a rear spoiler with a radiator en...   Dec 5 2014, 10:39 PM
r_towle   Mike, don't do it. Keep it aircooled and drive...   Dec 5 2014, 10:46 PM
veekry9   https://www.google.ca/search?q=f1+chassis&a...f-e%...   Dec 6 2014, 02:35 AM
veekry9   The fan is a centrifugal pump, just like any cent...   Dec 6 2014, 03:10 AM
mgp4591   Interesting side rad setup... would you have that ...   Dec 6 2014, 03:16 AM
veekry9   Step to the left. Step to the right.   Dec 6 2014, 04:33 AM
veekry9   Not the first.   Dec 6 2014, 07:24 AM
mepstein   it's easy to cool when the car is moving. It...   Dec 6 2014, 07:46 AM
DBCooper   Yup, lots of theory to go around, but to answer th...   Dec 6 2014, 07:47 AM
veekry9   http://www.performanceforums.com/forums/sh...he-po...   Dec 6 2014, 08:25 AM
76-914   I love to watch this subject resurface. A lot of a...   Dec 6 2014, 10:04 AM
veekry9   "RSK must be Peter Harburg's, because the...   Dec 6 2014, 11:48 AM
messix   the advantage of front mount is that once the car ...   Dec 6 2014, 12:35 PM
veekry9   If you planning to race it exclusively,a rad mount...   Dec 6 2014, 11:24 PM
thelogo   Where do water cooled 911 s mount the radiator C...   Dec 7 2014, 07:07 PM
Chris914n6   ^^ most newer mid engine cars do the corner rads a...   Dec 7 2014, 08:27 PM
veekry9   http://www.fiero.nl/forum/Forum3/HTML/000116-29.ht...   Dec 7 2014, 09:03 PM
mgp4591   There's alot of room for the radiator out in b...   Dec 7 2014, 10:13 PM
JRust   My NA 2.5 subaru leaves a bunch of room in the tru...   Dec 7 2014, 10:19 PM
Andyrew   I think it has all to do with the size of the moto...   Dec 8 2014, 09:22 AM
thelogo   How about Targa top mount As crazy as it sounds ...   Dec 8 2014, 11:32 AM
veekry9   There's alot of room for the radiator out in ...   Dec 8 2014, 12:27 PM
Chris914n6   I crunched some numbers. Based on a few sedans I ...   Dec 8 2014, 12:33 PM
fiid   It seems doable to do radiators in the engine bay,...   Dec 8 2014, 12:34 PM
McMark   Maybe a centrifugal fan on the crank wheel that bl...   Dec 8 2014, 12:53 PM
SirAndy   Logically, if a 3.6 can work, you should be able t...   Dec 8 2014, 01:38 PM
sixnotfour   :D   Dec 8 2014, 02:12 PM
DBCooper   The question was whether a radiator had been succe...   Dec 8 2014, 03:21 PM
76-914   Paul makes a good point re: heat sink. I watched i...   Dec 8 2014, 08:13 PM
Andyrew   You know what would be an interesting fail safe, I...   Dec 8 2014, 10:50 PM
RobW   You could mount an oil cooler right behind the 914...   Dec 9 2014, 12:03 AM
veekry9   You know what would be an interesting fail safe, ...   Dec 9 2014, 01:06 AM
timothy_nd28   Laying a radiator flat in the front trunk?   Jan 19 2015, 01:28 AM
Mueller   Laying a radiator flat in the front trunk? Go...   Jan 19 2015, 04:45 PM
Mike Bellis   I had a radiator built to lay flat in the front tr...   Jan 19 2015, 09:27 AM
Andyrew   I had a radiator built to lay flat in the front t...   Jan 19 2015, 09:57 AM
rdauenhauer   Scott Thacher was the guy who showed up in WCR 05 ...   Jan 19 2015, 09:44 AM
rick 918-S   Scott Thacher was the guy who showed up in WCR 05...   Jun 26 2015, 03:25 PM
Andyrew   [quote name='rdauenhauer' post='2135972' date='Ja...   Jun 26 2015, 06:25 PM
DBCooper   Cool, this thread came back. In the meantime I ra...   Jan 19 2015, 10:05 AM
DBCooper   Unfortunately a lot of rear-mount cooling projects...   Jan 19 2015, 10:58 AM
3d914   OK, here's mine. Not done, but in process. I h...   Jan 19 2015, 01:59 PM
Mueller   Crazy idea time..... Still have "something...   Jan 19 2015, 04:57 PM
DBCooper   I've seen finned aluminum tubing a bit like th...   Jan 19 2015, 06:56 PM
Dave_Darling   Talk to Chuck at Elephant Racing in SJ. They do m...   Jan 19 2015, 07:10 PM
timothy_nd28   Trane has been using this for decades, highly high...   Jan 19 2015, 07:55 PM
Mueller   Trane has been using this for decades, highly hig...   Jan 19 2015, 08:03 PM
Mueller   New Lamborghini Huracan has rear mounted radiators...   Jun 26 2015, 10:45 AM
Chris H.   Yes, always pull air, never push (Mike Bellis). ...   Jun 26 2015, 05:22 PM
914forme   Motorcycle Rads I have thought about several times...   Jun 26 2015, 07:50 PM
Chris914n6   Looking at racing rads for toyota celica/mr2/spyde...   Jun 29 2015, 02:39 PM
Andyrew   You talking about these puppies? http://www.ebay....   Jun 29 2015, 08:51 PM
Chris H.   You talking about these puppies? http://www.ebay...   Jun 29 2015, 11:40 PM
Chris914n6   You talking about these puppies? http://www.ebay...   Jun 30 2015, 02:15 PM
Bill D   For the TD I was able to fit the radiator next to ...   Jun 30 2015, 06:36 PM
Mike Bellis   For the TD I was able to fit the radiator next to...   Jun 30 2015, 07:24 PM
Bill D   My project is no where near as ambitious as your...   Jul 1 2015, 05:57 AM
Andyrew   Impressive that you were able to make that work...   Jun 30 2015, 09:42 PM
matthepcat   I like it. As I understand it the diesel runs coo...   Jul 1 2015, 09:43 AM
Bill D   I like it. As I understand it the diesel runs co...   Jul 1 2015, 12:01 PM
flmont   Iam considering a 4.3 ltr chevy v6 system,.with a...   Jul 7 2015, 07:13 PM
Mueller   Not a 914, but I think close enough, went to small...   Feb 5 2017, 04:13 PM
Mueller   I think what might help for any of these type swap...   Feb 5 2017, 04:16 PM
mepstein   Why don't you do it and report back. You don...   Feb 5 2017, 06:27 PM
sotaro   Why don't you do it and report back. You don...   Feb 27 2017, 09:21 PM
Rand   Aren't there examples of mid-engined sports/su...   Feb 27 2017, 10:03 PM
mepstein   Are the radiators in boxters in the front?   Feb 28 2017, 06:27 AM
Andyrew   Yes. Boxsters have two small ones and boxster S...   Feb 28 2017, 07:05 AM
mepstein   Yes. Boxsters have two small ones and boxster S...   Feb 28 2017, 07:49 AM
Andyrew   Yes. Boxsters have two small ones and boxster S...   Feb 28 2017, 09:17 AM
914forme   Positive pressure is king to cooling. And there i...   Feb 28 2017, 09:03 AM
Mueller   Twin side mounted radiators, good enough for a big...   Feb 28 2017, 04:54 PM
mepstein   Twin side mounted radiators, good enough for a bi...   Feb 28 2017, 07:04 PM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd February 2025 - 10:36 AM
