Back to square one |
JoeSharpOld |
Sep 10 2004, 07:05 PM
Does it seem cold to you Group: Members Posts: 361 Joined: 29-April 04 From: Camping in Neverland Member No.: 2,001 |
This started about 6 months ago as what I thought was as intermiten open in a loom. Its /L. car and I've replaced the Loom (Thank you Mr. Blowsby) all lines and hoses, intake manifold gaskets and boots, adjusted the valves, new injectors. What it is doing is fouling plugs at 3/2.
(IMG:style_emoticons/default/headbang.gif) Whats up wit dat (IMG:style_emoticons/default/unsure.gif) Joe |
nebreitling |
Sep 10 2004, 11:53 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
QUOTE(phantom914 @ Sep 10 2004, 09:05 PM) Umm... how would the CHT cause anything different to happen to cylinders 2 and 3? (IMG:style_emoticons/default/huh.gif) Shouldn't the ECU lean or richen the same for all cylinders based on the CHT? that's what i would think. i'd replace the FI trigger points, rotor, cap, plug wires, and double check all wiring. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:04 PM |
