anyone know this car?, orange flared factory six in idaho.. |
vortrex |
Sep 11 2004, 01:16 AM
Senior Member Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
not a lot of details in the ad, but looks good. anyone seen it before?
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...2489504255&rd=1 |
vortrex |
Sep 11 2004, 02:35 PM
1970 914-6GT
VIN #9140430238 EXTERIOR ALL NEW INSIDE AND OUT, SIGNAL ORANGE PAINT (L 20 E) NEW CHROMED BUMPERS GT FENDER FLARES (GLASS) ALL NEW TAIL AND TURN INDICATOR LENSES NEW FRONT AIR DAM NEW GT ROCKER PANELS INTERIOR ALL NEW CARPETING INCLUDING TRUNK NEW OEM DASH RECONDITIONED SEATS, DOOR PANELS AND DASH FACIA NEW PANASONIC CQ-DP36 REMOVABLE FACE AM-FM CD PLAYER PIONEER 5” 100 WATT SPEAKERSIN STOCK HOUSEINGS UPDATED SHORT SHIFT KIT WITH ALL NEW SHIFT BUSHINGS NEW LEATHER WHEEL COVER ALL NEW BRONZEPEDAL BUSHINGS AND NEW PEDAL PADS NEW INTERSTATE BATTERY WHEELS AND SUSPENSION FUCH ALLOYS WITH BLCK CENTERS POLISHED LIP, CENTER CAP AND LUGS 7 X 15 FRONT WITH NEW BRIDGESTONE RE71 205 X50 X 15 TIRES 8 X 15 REAR WITH NEW BRIDGESTONE RE 71 225 X 50 X 15 TIRES KONI STRUT INSERTS IN FRONT KONI REAR SHOCKS 180 LB REAR SPRINGS 19MM FRONT SWAY BAR TURBO TIE ROD ENDS NEW BRAKE PADS AND FLUID STAINLESS STEEL BRAKE LINES ENGINE 5800 MILES ON COMPLETE (TOP AND BOTTOM) REBUILD 2.2 LITER S (CRANK, RODS, Ps & Cs HEADS) ORIGINAL ENGINE CASE BALANCED TO WITHIN 1 GRAM NEW MAHLE PISTONS AND CYLINDERS CARRERA TENSIONERS ALL MACHINING DONE BY LUKES AND SHORMAN OF ALBANY, CALIFORNIA ALL NEW VALVES (SODIUM FILLED EXHAUST) ALL NEW VALVE GUIDES AND UPDATED STEM SEALS ALL NEW WRIST PIN BUSHINGS REBUILT OIL PUMP TURBO OIL PRESSURE RELIEF VALVE UPDATED OIL PASSAGE MACHINING (RECCOMMENDED BY BRUCE ANDERSON) NEW EXPANDABLE OIL RETURN TUBES PRESSURE FED CHAIN TENSIONEERS RECONDITIONED AND MAGNAFLUXED CRANKSHAFT RECONDITIONED AND MEGNAFLUXED RODS ALL NEW ROD BOLTSAND NUTS RECONDITIONED AND MAGNAFLUXED ROCKER ARMS RECONDITIONED HEADS BOSCH CENTRIFICAL ADVANCE DISTRIBUTOR NEW PLATNUM SPARK PLUGS ALL NEW SPARK PLUG WIRES ALL SHEET METAL POWDER PAINTED SOLAR BLACK SIGNAL ORANGE ENGINE SHROUD REBUILT ALTERNATOR LIKE NEW WEBER 40 IDA CARBURETORS, WITH PMO FUEL PICKUP, BAFFELING AND VENTING MODIFICATIONS) 32MM VENTUIES 130 MAIN JETS 155 IDLE JETS 180 AIR CORRECTION JETS F3 EMULSSION TUBES K& N FILTERS AND RAIN SHIELD COVERS NEW SACHS CENTER SPRING CLUTCH, T/0 BEARING AND PRESSURE PLATE RESURFACED FLYWHEEL WITH NEW FLYWHELL BOLTS REBUILT TRANSMISSION WITH A TIGHT 1ST GEAR AND SYNCRO SWEPCO TRANSMISSION FLUID SOLID TRANSMISSION MOUNTS RECONDITIONED HALF-STAFTS MISCELANIOUS ALL MAINTENANCE RECORDS ALL SERVICE PART INVOICES ALL SUBLET LABOR INVOICES |
Lo-Fi Version | Time is now: 26th September 2024 - 06:26 PM |
