Motor Value, Sanity Check - Asile 5 |
mr914 |
Jul 6 2015, 08:33 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
With the recent seeming increase in value of the 911 motors, I need to establish a market value for my motor that is apart.
2.0 Early 911 Aluminum Case Bored for 2.7 MFI P&Cs No other upgrades to case that I know of. Early style Oil Pump 2.7 Crank and Rods – Stock sizes 2.2T heads – At least 3 seats are bad, all guides need replaced Later style Cam boxes 2.7 MFI Pistons and Cylinders Solex Cams with non-pressure fed tensioners Early Distributor Bosch CD Box Set of Non-Italian Webers w/manifolds linkage Aeroquip – Fuel lines and fittings Early Style Alternator/Blower and housing What do you thing is a value for this motor disassembled? |
mr914 |
Jul 6 2015, 09:07 PM
No new parts
Was a running motor in the 80's Sat for 25 plus years #3 cylinder was dead - No compression from corroded seats. I was thinking $4-5k to get back together. Riings Bearings rebuilt Heads Polish Crank and Rods Case Gaskets And lots of time.... Attached thumbnail(s) |
Lo-Fi Version | Time is now: 6th January 2025 - 04:32 PM |
