Cutting spot welds, gotta start somewhere :) |
bryanthompson |
Sep 12 2004, 08:21 AM
Check it out... 3 loops! Group: Members Posts: 208 Joined: 23-April 04 From: elwood, ne Member No.: 1,970 |
I started on my 914 project and decided to do the trunk first. So, i started chipping away bondo from the inside of the bottom of the trunk and found (suprise!) more rust than expected. So, the bottom part of my trunk pan has to be replaced.
Anyway, i bought a spot weld cutter yesterday, but something about it makes me wonder. The tool looks just like this: (IMG:http://www.ingallseng.com/graphics/Prodcut_Pictures/92900.jpg) So, should i trim down the spikey thing or let it go through the whole car? I realize i'll be welding it back up so it wouldn't be the worst thing in the world if it made a hole, but what i'm worried about is the bending effect putting that much force will have... like i'll end up with little pimples around the hole left by the spike (not the saw part). (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/monkeydance.gif) |
Slowpoke |
Sep 12 2004, 08:49 AM
Member Group: Members Posts: 116 Joined: 1-June 03 From: Tucson, AZ Member No.: 768 |
Those tools are handy. I just drill a hole in the panel the size of the spike coming out of it. This gives me better control of the cutting and a small 1/8 hole is easy to mig close on the piece I'm trying to save. But, you do have to be carefull not to cut all the way thru both pieces of metal. Because, you are defeating the purpose of the stop feature (that's why the spike it there, you adjust the stop from the other end of the tool). I also have luck just drilling with a drill bit the spot weld itself. All it takes is patience either way.
Lo-Fi Version | Time is now: 26th September 2024 - 11:43 AM |
