GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
FS - Used Weltmeister 22mm front sway bar with the triangles that go under the gas tank for mounting. As you can see it will need some clean up and new bushings. It was from a 73 project car that I picked up. The PO installed the bar and some other "go fast " stuff on the chassis then pushed it outside behind the barn where it sat for approx. 10 years. New bars sell for $350 - $400 depending where you get them. Based on the condition of the drop links I will take $220 and that includes shipping to you in the USA.
Sold Attached image(s) ![]() ![]() ![]() ![]() ![]() |
madmax914 |
Member ![]() ![]() Group: Members Posts: 204 Joined: 16-February 14 From: Salem, Oregon Member No.: 17,007 Region Association: Pacific Northwest ![]() |
I have that same sway bar, do you know where I can buy new bushings? Having a hard time finding them. These are not tapered like the ones Pelican sells.
Any help would be appreciated. |
john77 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California ![]() ![]() |
I have that same sway bar, do you know where I can buy new bushings? Having a hard time finding them. These are not tapered like the ones Pelican sells. Any help would be appreciated. Paragon have them, I bought a set about a month ago to replace the old ones that were on mine. The 22mm aren't listed on the site, only the 19mm, but if you contact Jason either through here (member: Paragon) or through their site he should be able to find you some. http://www.paragon-products.com/ [Sorry for hijacking your thread, Garold.] |
Lo-Fi Version | Time is now: 26th June 2024 - 01:44 AM |
