Front Caliper clearance question 3.5" spacing 5 Lug, Wilwood Superlite's |
Vysoc |
Jul 12 2015, 12:28 PM
Vysoc Group: Members Posts: 588 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
Hello World,
I am reworking my front 5 lug struts,shocks and calipers. I was able to pick-up a set of Wilwood Superlite 3.5" spacing front calipers with 3 sets of additional brake pads. Upon doing a dry run on fit, I needed to trim my brake dust covers slightly but I noticed that the caliper did not line up in the center of the rotor. Rotors are new Sebro 405 43001 098. Is it possible to use washers to adjust the caliper position to center. I would obviously purchase longer bolts to make sure that the same amount of thread is holding in the strut. The adjustment distance would be approximately 5mm. Thanks, Vysoc (IMG:style_emoticons/default/flag.gif) |
Mike Bellis |
Jul 13 2015, 08:42 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Your bleeder screws are on the bottom. Just a mock up right?
Lo-Fi Version | Time is now: 19th September 2024 - 05:57 PM |
