2056 Build, Just starting teardown; some questions |
Spoke |
May 31 2015, 06:55 PM
Jerry Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Finally getting into building a 2056 for my 914. Plan is to rebuild one of the two 2L engines I have with 96mm AA P/Cs. For induction, I have D-Jet from one of the 2L engines with a good MPS and set of Weber IDF40s. I would like to stay with FI but will consider using the Webers.
The engine will have ceramic coated SSHE along with a Bursch muffler. The first engine I bought was advertised as a 2L core with FI. In reality the engine was "cored". There is a hole about 3/8 x 1/2 inch in the case. Looks like the engine was run even with the hole as there is a good amount of dirt+oil on the fins of cylinders 3&4. Also one of the spark plug threads is stripped on cylinder #4. The seller said he would give me a line bored case that he has but I've yet to see it. I bought the engine in Aug of last year so I'm losing hope of getting the case; This ranks up there with one of my worst purchases. Since the first engine's case was trashed and the seller hasn't come through with the promised replacement case, I purchased a 2nd engine from Brad Mayeur that had been running. This one came with the Webers and likely will be the basis of my engine. |
Han Solo |
Jul 11 2015, 08:20 PM
Member Group: Members Posts: 288 Joined: 30-September 13 From: Middle Tennessee Member No.: 16,456 Region Association: South East States |
Larger intake valves than 2.0L OEM heads?
Spoke |
Jul 17 2015, 11:10 PM
Larger intake valves than 2.0L OEM heads? Can't tell if they're different. I didn't measure them before reassembly. Here's a question about the taco plate o-ring: Do I install dry, lube with oil, RTV, gasket sealant? Attached thumbnail(s) |
Lo-Fi Version | Time is now: 26th June 2024 - 12:37 AM |
