Blue Porscheru Conversion, Subaru 2.5 SOHC NA with Suby Tranny |
R_u_dd |
Jul 25 2015, 11:09 PM
Member Group: Members Posts: 154 Joined: 3-March 14 From: Grants Pass, Oregon Member No.: 17,072 Region Association: Pacific Northwest |
I started this project back in May of 2014 and wanted to share the journey with my friends and family. There's something appealing to people about taking a left-for-dead vehicle and bringing it back to life. I hope this build thread is a bit different than the others. It's a Subaru conversion which is not as common. I am/was a newbie. This is my first car restoration, if you can call it that. My welds are not pretty, but I've improved and learned throughout this process. This is a great car for a first restoration. It's light, simple, and very cool- mid engine with a targa top. This is the plan- We are starting with a 1971 tangerine 914 with light to moderate rust, nothing too serious. The original engine was a 1.7. Like so many other 914's it ran but has been sitting for a long time. The engine seems too far gone to try to rebuild it= lots of rust and corrosion. Powerplant: 2003 Subaru Impreza TS 2.5 SOHC, Natuaral- No Turbo, Why? Plenty of Power for me and no turbo lag. See Engine Choices thread. Transmission: Subaru 5MT 2003 Impreza TS ECU from: 2003 Subaru Impreza TS Electronics: Wiring Harness simplified by Small Car Performance Axles: 944 axles and CV's with Subaru inside CV- 4 lug for now. 914 suspension. No fender flares Voltage Blue Metallic: (Honda color), Painted Sail Panels. Before Pictures (IMG:http://www.914world.com/bbs2/uploads_offsite/i1301.photobucket.com-17072-1486250894.1.jpg) The Future Look- Concepts The 914 visualizer, a very cool app. Current Look: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.imgur.com-17072-1607919164.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.imgur.com-17072-1607919164.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.imgur.com-17072-1607919165.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1301.photobucket.com-17072-1459666779.1.jpg) Contents Axles Blasting Glass Bead Videos Battery Tray Area Battery and Tray Budget Scenarios Brakes Bumper - Valence Clutch Electronics Engine Discussion Engine Mount Engine Work Floor Pans and Engman Kit Fuel Pump Fuel Tank (Cleaning with Electrolysis) Paint Prep and Metal Work Paint Prep Continued Radiator Seats and Interior Seats Re-upholstery Links Transmission Transmission Mount Videos This thread is for entertainment purposes only. I am not a certified mechanic. There are many that have pioneered the suby conversion before me, but this is my story. Hope you enjoy this thread! Chris (IMG:http://www.914world.com/bbs2/uploads_offsite/i1301.photobucket.com-17072-1486249676.1.jpg) |
JRust |
Jul 27 2015, 07:50 PM
914 Guru Group: Members Posts: 6,310 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Just for a reference. I bought the Sawtooth build from Dean. It has a 2001 SOHC NA 2.5 with a performance build & performance heads. Running an aftermarket Stinger ECU from Outfront. Equal length header to a single exhaust. It dyno'd at 158 to the rear wheels. It pulls great & I love driving it. So just wanted to get realistic HP numbers for you. It's fine seeing it on paper in places. It always seems to drop in the real world application though.
On all your welding of your floors & long kit. I have not seen any type of door brace. It's pretty easy to get a twist in your chassis or mess up your door gaps. Just hoping you did in fact have it braced with all your welding. If not I'll keep my fingers crossed it is all good. Looks like you did a good job installing the floors. Really great progress on your car bud. Following your thread closely (IMG:style_emoticons/default/smile.gif) |
R_u_dd |
Jul 29 2015, 08:28 AM
Just for a reference. I bought the Sawtooth build from Dean. It has a 2001 SOHC NA 2.5 with a performance build & performance heads. Running an aftermarket Stinger ECU from Outfront. Equal length header to a single exhaust. It dyno'd at 158 to the rear wheels. It pulls great & I love driving it. So just wanted to get realistic HP numbers for you. It's fine seeing it on paper in places. It always seems to drop in the real world application though. On all your welding of your floors & long kit. I have not seen any type of door brace. It's pretty easy to get a twist in your chassis or mess up your door gaps. Just hoping you did in fact have it braced with all your welding. If not I'll keep my fingers crossed it is all good. Looks like you did a good job installing the floors. Really great progress on your car bud. Following your thread closely (IMG:style_emoticons/default/smile.gif) The HP should be double the original car regardless of what I end up with at the wheels. If the original engine was rated at 80, and the new engine is rated at 165. I would assume both engines would lose a proportional amount of horsepower in the drive lines. I was very careful on the welding. The car had bigger issues though to start with since it had been hit a couple times (and covered with bondo). The gaps are definitely off, but it's not a show car. My body guy has some tricks up his sleeve to fix this though... My gaffes are worse then my gaps though... |
Lo-Fi Version | Time is now: 27th December 2024 - 07:33 AM |
