> Suby Trans whining on decel (with vid), Fixed it...I'm stoopid.
Chris H.
post Jul 28 2015, 08:04 PM
OK guys, I'm hoping someone knows WTF this is...I bought my 2006 WRX trans from a reputable guy on NASIOC. It only has 66k on it. The 2006 WRX was a 2.5T so more than capable of handling the 3.3L engine. It has a whine only on decel, and ONLY in gears 3-5. It has plenty of trans oil in it, Subaru OEM ($$$), compensating for the angle and missing center diff. I've done a lot of research on bad Subaru transes and when they go out there are a lot of other "bad noises". Terminal noises usually occur all the time, more often on accel than decel. There is NO grinding, ticking, squealing, humming, etc. in this thing. Just the "school bus whine" on decel.
Have a look at this:
https://www.youtube.com/watch?v=10Xj8GA6BDY
Just to clarify my comments on the video:
1. I ran the test several times and I ONLY got the whine on decel
2. It ONLY whines in gears 3-5 and gets louder with each gear
I was a little wishy-washy on those those things in the vid.
I had one odd thought...could it be the gear selector is slightly off kilter and rubbing something in gears 3-5 (IMG:style_emoticons/default/idea.gif) ?
There were a few threads on NASIOC that said "just ignore it"..hard to do that when it's so loud and I would hate to make it worse if there something wrong with it...but...it's hard to believe there's something too terribly wrong when it shifts well with no grinding, never pops out of gear, hauls ass, etc.
Anyone have thoughts on what it is?
Chris H.
post Jul 30 2015, 08:47 AM
So that was it. NO whine AT ALL! Thanks for all the advice. It led me to the problem.
I think the last spacer washer was in a spot where it wasn't intuitive that it should stay or go (unless you read the MANUAL (IMG:style_emoticons/default/blink.gif) ) and when I took it out it made the spool flush with the splines on the trans. So it made sense but was totally WRONG. Just like an Enzo Fiero.
Chris H.   Suby Trans whining on decel (with vid)   Jul 28 2015, 08:04 PM
JRust   Normally the guys on Nasioc are pretty good. WTF i...   Jul 28 2015, 10:29 PM
Chris H.   Good question...I was wondering if it was the CV b...   Jul 28 2015, 11:37 PM
IanJ   Have you checked your 2wd lockout is fitted correc...   Jul 29 2015, 06:55 AM
Chris H.   Great question...I should have mentioned that I to...   Jul 29 2015, 07:05 AM
76-914   You didn't mention it was 3/5 only. :chair: I...   Jul 29 2015, 08:31 AM
Chris H.   I know...just figured that out when I put it up on...   Jul 29 2015, 08:43 AM
76-914   Chris, if that noise goes away when you disconnect...   Jul 29 2015, 09:07 AM
Chris H.   Yeah I'll try that. Bob will be rolling his e...   Jul 29 2015, 09:30 AM
IM101   Hmmmm, have not seen that before, my first guess w...   Jul 29 2015, 12:56 PM
ThePaintedMan   That sucks Chris! Have you had a chance to pop...   Jul 29 2015, 01:13 PM
DBCooper   To me it sounds like a harmonic vibration, not gea...   Jul 29 2015, 02:29 PM
Chris H.   No significant debris in the drain plug George. ...   Jul 29 2015, 02:35 PM
mgp4591   Looks like you were checking for vibrations in the...   Jul 29 2015, 05:50 PM
Chris H.   Update....it's possible that someone (me) may ...   Jul 29 2015, 08:23 PM
mgp4591   Update....it's possible that someone (me) may...   Jul 30 2015, 12:53 AM
Chris H.   Ian did. That wasn't it though I don't th...   Jul 30 2015, 07:02 AM
Chris H.   So that was it. NO whine AT ALL! Thanks for ...   Jul 30 2015, 08:47 AM
IM101   Glad we could help Chris.   Jul 30 2015, 09:48 AM
76-914   Hot Damn, you da Man! :Qarl: I'll tell on...   Jul 30 2015, 05:51 PM
- Lo-Fi Version Time is now: 20th April 2025 - 06:40 AM
