> Subaru Transmission into 914, DAMN that turned out good!!
DBCooper
post Jan 12 2010, 06:31 PM
14's in the 13's with ATTITUDE
Some photos of my 914 being fitted with a WRX transmission. I'm sorry, we replaced bushings, adjusted and aligned three times and that 901 never even got close to being acceptable. The WRX motor was such a huge improvement over the VW that it only seemed logical to make the transmission just as modern. And "while we're in there" the air-to-air intercooler is being replaced by a water to air. You just don't get the air flow in the back of the car you'd want to make big power, and the next step with this car will be an STI motor. Power is addictive. Yes, I know better and you've been warned.
Anyway, the WRX five speed with Quaife gets introduced to engine.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145993.1.jpg)
The forest of jackstands as positioning is worked out.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145994.2.jpg)
The WRX transmission axle outlets are a little closer to the flywheel than the 901, which meant the engine had to be moved back to keep the axles aligned with the stubs.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145995.3.jpg)
Flipped manifold. Enough space in there now for an EZ30 six, easy. Nice looking hellhole too, don't you think? Still needs detailing of course, but first things first.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145995.4.jpg)
But moving the engine back meant he had to box a small part of the rear trunk. That's OK, this car isn't for hauling luggage anyway. Or lawn tools. Or groceries.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145996.5.jpg)
Cable shifter at the transmission. Beautiful work.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145997.6.jpg)
And inside the car, the modified MR2 shifter. Feels notchy, accurate, and good, which is what this is all about. That and more strength, especially in first.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145998.7.jpg)
A video of the shifter, still in the prototype stage, showing the action in the front and the rear.
https://www.youtube.com/watch?v=ncmaxYd1WNI
Ask Abby what she thinks of Grandpa's car. She likes to show off those pretty new teeth.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145998.8.jpg)
The water-air intercooler. It will go just ahead of the engine on the driver's side.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268145999.9.jpg)
In the car, you can see part of the new cradle, just tacked for the moment.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268146000.10.jpg)
Axles are aligned.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268146001.11.jpg)
Business end, seen from the rear. It looks so good we'll probably go without a valence, it's gotta be seen. I can't wait until in the rearview mirror I see another 914 guy who's pulled up behind and is trying to figure out what all happened back there.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268146001.12.jpg)
This work is being done by a wizard at a shop called 40-Thirteen in Modesto, CA. Quality of work is unmatched. If you're curious there are a lot more pictures of this transmission project, the engine cradle, what the car looked like with just the WRX motor before these changes, or more pictures of that beautiful granddaughter in an album at: http://photobucket.com/Corinthiano
More to come later. It was a monster before, but you had to be real gentlemanly with the shifter. To hell with that. I can't wait.
DBCooper
post Mar 9 2010, 07:38 AM
Some delay because the Tilton pedals were backordered. They're now in, though not yet plumbed. At the end of the day this is easier than modifying the 914 cluster to add a clutch master. Not only that I just plain like Tilton pedals.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i379.photobucket.com-2618-1268141909.1.jpg)
Not too far from driving it now. Only bummer is in the background of every one of these photos I see clean-up and finish work that still has to be done. That's cool, get it running the way I want first and then go back through everything to make it all pretty.
914forme
post Aug 1 2015, 05:29 AM
QUOTE(DBCooper @ Mar 9 2010, 09:38 AM) *
Are you using Howe Racing G3 Masters, and what sizes did you use? If you used the 3/4" how does the clutch pedal feel since your using the stock Subaru slave?
Needed to re-read the thread, found it in an earlier post
"I used Tilton pedals to get a hydraulic M/C (read the whole thread, it's described with photos). Only down side is that using the smallest available Howe M/C's I still have too much pedal pressure (Carrera front calipers, 914 front on the rear), so I'm looking to convert to calipers with bigger pistons."
DBCooper   Subaru Transmission into 914   Jan 12 2010, 06:31 PM
DBCooper   Hmm... anyone know how to embed a video, or am I g...   Jan 12 2010, 06:32 PM
SirAndy   Hmm... anyone know how to embed a video The FAQ k...   Jan 12 2010, 06:53 PM
DBCooper   Wow, that FAQ really does know! Thanks, Andy,...   Jan 12 2010, 07:01 PM
rick 918-S   That is one sweet looking engine and transaxle mou...   Jan 12 2010, 07:11 PM
budman5201   That is one sweet looking engine and transaxle mo...   Jan 12 2010, 09:29 PM
DBCooper   i swear i have seen that "kinda" mount ...   Jan 13 2010, 11:37 AM
rickthejetman   what brand of intercooler are you using? i am also...   Jan 12 2010, 09:42 PM
Zundfolge   http://i379.photobucket.com/albums/oo234/paulilli...   Jan 13 2010, 07:52 PM
rickthejetman   [quote name='DBCooper' post='1261139' date='Jan 1...   Jan 13 2010, 08:06 PM
DBCooper   Hmm...that almost looks like there's room for...   Jan 14 2010, 09:04 PM
dlo914   What's involved in flipping the intake manifol...   Jan 14 2010, 11:35 AM
budman5201   What's involved in flipping the intake manifo...   Jan 14 2010, 07:44 PM
tat2dphreak   that looks great man!!   Jan 14 2010, 12:22 PM
Porcharu   Damn are you reading mind? That is almost exactly...   Jan 14 2010, 09:31 PM
DBCooper   Damn are you reading mind? No, I didn't, I s...   Jan 15 2010, 05:40 AM
Sleepin   Wow! Whoever does the welding on that stainles...   Jan 15 2010, 08:28 AM
lucky14   Hi, How much hp can that transmission take?   Jan 17 2010, 02:34 PM
DBCooper   How much hp can that transmission take? I think ...   Feb 7 2010, 12:58 PM
Bno   Hi DB. Your car is looking great. Do you have so...   Jan 17 2010, 03:54 PM
DBCooper   OK, I’ve been traveling so haven’t pos...   Feb 7 2010, 01:27 PM
DBCooper   It runs again! Doesn’t roll quite yet, ...   Feb 16 2010, 02:09 PM
DBCooper   Some delay because the Tilton pedals were backorde...   Mar 9 2010, 07:38 AM
914forme   Some delay because the Tilton pedals were backord...   Aug 1 2015, 05:29 AM
DBCooper   OK folks, it’s party time!! It runs...   Mar 17 2010, 01:55 PM
Andyrew   Uh, Where is this shop at? You realize IM in mod...   Mar 17 2010, 03:44 PM
DBCooper   Uh, Where is this shop at? You realize IM in mo...   Mar 18 2010, 06:16 AM
Andyrew   Uh, Where is this shop at? You realize IM in m...   Mar 18 2010, 10:20 AM
DBCooper   It would be really cool to run the two! What ...   Mar 20 2010, 08:09 AM
Andyrew   Trapping 106mph is pretty damn respectable. I trap...   Mar 20 2010, 06:24 PM
DBCooper   We tuned it a tad fat with max 10 pounds boost s...   Jun 14 2014, 07:00 PM
Andyrew   We tuned it a tad fat with max 10 pounds boost ...   Jun 15 2014, 12:47 PM
Root_Werks   WOW!   Mar 18 2010, 04:57 PM
markb   WOW! :agree:   Mar 21 2010, 06:29 AM
Porcharu   Very nice job. Nice that you don't think a si...   Mar 18 2010, 05:47 PM
Eric_Shea   Amazing fab work is an art that goes un-noticed by...   Mar 20 2010, 08:26 AM
campbellcj   Wow, very cool project and it is inspiring to see ...   Mar 20 2010, 10:57 AM
strawman   Saw this car today in Sac. Jeff does GREAT work --...   Mar 21 2010, 01:05 AM
Rico Suave   Looks excellent....be careful coming out of corner...   Mar 21 2010, 11:57 AM
WRX914   Looks excellent....be careful coming out of corne...   Mar 22 2010, 04:04 PM
budman5201   Looks excellent....be careful coming out of corne...   Mar 27 2010, 12:30 PM
okieflyr   That's a great execution on your conversion, a...   Mar 22 2010, 05:06 PM
DBCooper   As part of their destructive testing program the k...   Mar 25 2010, 05:52 PM
strawman   They say the front end pushes badly at low speeds...   Mar 26 2010, 11:13 PM
DBCooper   They say the front end pushes badly at low speed...   Mar 27 2010, 06:08 AM
Andyrew   As part of their destructive testing program the ...   Mar 27 2010, 06:59 PM
DBCooper   I think rear springs are 140, Koni adjustables on ...   Mar 28 2010, 04:13 PM
roachghia70   You can hear wheelspin down some straights on al...   Mar 29 2010, 12:29 PM
d914   I found from my track days that yes you steer with...   Mar 28 2010, 04:31 PM
Andyrew   The point of the car is to have it neutral at most...   Mar 29 2010, 01:26 PM
DBCooper   Hey Thomas, welcome! That's my son, the I...   Mar 29 2010, 10:30 PM
Rico Suave   2nd gear? Welcome to AX.....I haven't seen 3r...   Mar 29 2010, 10:33 PM
KaptKaos   Nice build. Which axles are those? With all th...   Mar 29 2010, 10:50 PM
Porcharu   I am pretty sure those are stock VW buss (100mm CV...   Mar 30 2010, 02:55 PM
ruby914   WOW! Fantastic job. Makes me want to grind ou...   Apr 4 2010, 11:54 AM
Rod   Amazing subaru build! One of the best if not ...   Sep 11 2010, 02:02 AM
jimkelly   one of my all-time favorites. can you break down ...   Sep 11 2010, 06:39 AM
badmiata   Many question! What yr sti did you pick and wh...   Oct 20 2010, 09:57 AM
ChrisNPDrider   Sweetness. Great to see the newest thinking in the...   Oct 20 2010, 12:52 PM
ChrisNPDrider   woops, double post, delete me this website never l...   Oct 20 2010, 12:52 PM
ChrisNPDrider   I want one   Oct 20 2010, 12:53 PM
DBCooper   Sorry I haven't been around lately, lots of th...   Oct 21 2010, 11:00 AM
sawtooth   Paul sure sorry to hear about your crash, hopefull...   Oct 21 2010, 04:21 PM
396   simply WOW!   Oct 21 2010, 05:56 PM
windforfun   Fantastic. Very impressive indeed.   Oct 21 2010, 06:01 PM
Britain Smith   Where did you get the red bushings? http://www.91...   Nov 4 2010, 12:18 AM
matthepcat   Has anyone considered fabricating & selling th...   Nov 30 2010, 08:10 PM
Porcharu   Yes, If I ever get the time (the swap is currentl...   Dec 1 2010, 06:40 PM
matthepcat   Steve, That's great!! I see that you...   Dec 3 2010, 12:38 PM
Brett W   I have built two already and could build you anoth...   Nov 30 2010, 11:01 PM
matthepcat   I have built two already and could build you anot...   Dec 1 2010, 11:53 AM
d914   you could look at mine   Dec 1 2010, 11:11 AM
Cupomeat   What a great build and car. I have never been muc...   Dec 1 2010, 01:39 PM
Garold Shaffer   What a great build and car. I have never been mu...   Dec 1 2010, 06:26 PM
Porcharu   What a great build and car. I have never been mu...   Dec 1 2010, 06:42 PM
DBCooper   Just got back from an after-dinner blast through t...   Jul 8 2011, 08:47 PM
sawtooth   Just got back from an after-dinner blast through ...   Jul 8 2011, 09:46 PM
Heater Guy   Just got back from an after-dinner blast through ...   Jul 12 2011, 12:38 AM
DBCooper   I used Tilton pedals to get a hydraulic M/C (read ...   Jul 12 2011, 06:55 AM
sawtooth   I know I also saw someone who used an early Subar...   Jul 12 2011, 09:11 AM
hsus2k   Hi newbie here, I've been following Jeff's...   Aug 10 2011, 11:26 AM
rs182   Anyway, Originally, I was sourcing a JDM WRX EJ2...   Sep 18 2011, 10:17 AM
ChrisNPDrider   If you intend to be on a race track 80-100%, those...   Aug 10 2011, 01:31 PM
IanJ   First off thanks for a great thread with fantastic...   Sep 17 2011, 11:57 PM
DBCooper   You're in Las Cruces? These days I'm spen...   Sep 18 2011, 02:06 PM
rs182   You're in Las Cruces? These days I'm spe...   Sep 18 2011, 02:15 PM
csdilligaf   the shop that did the work on this project is thir...   Apr 19 2012, 08:46 PM
DBCooper   You didn't get my PM? It's 40-Thirteen in...   Apr 20 2012, 12:52 PM
CptTripps   Quick question: Ever think of using a Boxster shif...   Oct 20 2013, 01:00 AM
pcar916   I understand you have some control with the DCCD b...   Oct 20 2013, 09:58 AM
r_towle   do you have pictures of what the kit for the trans...   Jun 14 2014, 09:40 PM
76-914   Rich, the "kit" is just a small sleeve. ...   Jun 15 2014, 08:09 AM
hbgsteve   Absolutely knock my socks off gorgeous. beyond wor...   Jan 19 2015, 07:24 PM
DBCooper   Yes, I'm tall and the Howe were the shortest m...   Aug 1 2015, 08:08 AM
mepstein   As a heads-up though, we converted my son's ...   Aug 1 2015, 11:46 AM
914forme   Yes, I'm tall and the Howe were the shortest ...   Aug 2 2015, 04:49 AM
DBCooper   You'll fit. I'm a bit taller and am total...   Aug 2 2015, 11:48 AM
914forme   Okay well thank you again, made for an interesting...   Aug 2 2015, 12:35 PM
76-914   Same thing on the shifter. My son has the same M...   Aug 2 2015, 03:36 PM
charliew   Gotta bump this thread DB kept up the updates and ...   Aug 2 2016, 08:55 PM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 18th April 2025 - 10:32 PM
