Lucky9146 |
Always Wanted A Bigger Go Cart ![]() ![]() ![]() Group: Members Posts: 1,675 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California ![]() ![]() |
Have a modified RX7 Oil Cooler that came with the car which was in process of a 6 conversion. Hoses are run to the engine bay ready to hook up to thermostat. Does anyone know if it matters if the oil enters from the top of cooler or bottom or does it really matter? Internal Tank thermostat is removed already I am going to run a Mocal. Appreciate the input especially from anyone actually running one. Thanks!
Attached image(s) ![]() |
screenguy914 |
Member ![]() ![]() Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California ![]() |
Have a modified RX7 Oil Cooler that came with the car which was in process of a 6 conversion. Hoses are run to the engine bay ready to hook up to thermostat. Does anyone know if it matters if the oil enters from the top of cooler or bottom or does it really matter? Internal Tank thermostat is removed already I am going to run a Mocal. Appreciate the input especially from anyone actually running one. Thanks! Typically, oil should exit from the top most fitting. That way, trapped air can circulate out of the cooler. Sherwood |
Lucky9146 |
Have a modified RX7 Oil Cooler that came with the car which was in process of a 6 conversion. Hoses are run to the engine bay ready to hook up to thermostat. Does anyone know if it matters if the oil enters from the top of cooler or bottom or does it really matter? Internal Tank thermostat is removed already I am going to run a Mocal. Appreciate the input especially from anyone actually running one. Thanks! Typically, oil should exit from the top most fitting. That way, trapped air can circulate out of the cooler. Sherwood Thanks Sherwood that makes sense and I hadn't though of that. |
lonewolfe |
Senior Member ![]() ![]() ![]() Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California ![]() |
Have a modified RX7 Oil Cooler that came with the car which was in process of a 6 conversion. Hoses are run to the engine bay ready to hook up to thermostat. Does anyone know if it matters if the oil enters from the top of cooler or bottom or does it really matter? Internal Tank thermostat is removed already I am going to run a Mocal. Appreciate the input especially from anyone actually running one. Thanks! Typically, oil should exit from the top most fitting. That way, trapped air can circulate out of the cooler. Sherwood Thanks Sherwood that makes sense and I hadn't though of that. I have this same oil cooler but it's not installed yet. Do you have any more pictures you can post of how it's mounted? Also, are those electric fans mounted on the back side of the cooler? |
Lucky9146 |
[/quote] Yes I have pictures of the fabricated frame and fans that I cannot take credit for making because the PO did it and a good job at that! Trying to post pictures but not working for me this time will try again later. Sorry |
lonewolfe |
[quote name='Lucky9146' date='Aug 3 2015, 02:36 PM' post='2218255']
I have this same oil cooler but it's not installed yet. Do you have any more pictures you can post of how it's mounted? Also, are those electric fans mounted on the back side of the cooler? [/quote] Yes I have pictures of the fabricated frame and fans that I cannot take credit for making because the PO did it and a good job at that! Trying to post pictures but not working for me this time will try again later. Sorry [/quote] Thanks for the reply! I'll keep an eye out for the pictures later. Does your setup have a shroud that covers the oil cooler and fans inside the trunk? |
Lucky9146 |
Yes I have pictures of the fabricated frame and fans that I cannot take credit for making because the PO did it and a good job at that! Trying to post pictures but not working for me to well trying
![]() Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 10th April 2025 - 05:36 PM |
