Pertronix wiring, Need to know which wire goes where! |
Cap'n Krusty |
Sep 14 2004, 12:59 PM
I know, I know .............. Being the one true anti-pertronix, I haven't a clue where the red and black wires go. Swapping a distributor to the guy's new Type 1 motor, and I need to know so I don't let all the smoke out ............................ TIA, the Cap'n
lapuwali |
Sep 14 2004, 02:37 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
WARNING: the Pertronix needs to get its power w/o the ballast resistor interfering. If the coil has an internal resistor, no worries, just hook the red to + and the black to -. If there's an external ballast resistor or a resistor wire to the + post, you need to hook the red wire up BEFORE that. If you try to run the Pertronix on less than 12 volts, it won' t work. I don't think it will smoke, but it will run like crap (assuming you can even get it started).
Lo-Fi Version | Time is now: 27th September 2024 - 04:15 PM |
