Monday, 14 April 2025
> Mazda RX7 Oil Cooler Flow, Does It Matter Which Way?
Lucky9146
post Aug 3 2015, 12:17 PM
Have a modified RX7 Oil Cooler that came with the car which was in process of a 6 conversion. Hoses are run to the engine bay ready to hook up to thermostat. Does anyone know if it matters if the oil enters from the top of cooler or bottom or does it really matter? Internal Tank thermostat is removed already I am going to run a Mocal. Appreciate the input especially from anyone actually running one. Thanks!
rgalla9146
post Aug 7 2015, 05:04 PM
Thank you Glen for posting the factory diagram.
I have that cooler and was going to use it for a GT project.
By handling it I realized that there was a thermo incorporated in it.
I've since found a better configuration(for me) but I wonder why someone wouldn't use the built-in thermostat ?
Two hoses to the front, built in by-pass, easy peasy ! nothing more needed.
Lucky9146   Mazda RX7 Oil Cooler Flow   Aug 3 2015, 12:17 PM
screenguy914   Have a modified RX7 Oil Cooler that came with the...   Aug 3 2015, 01:05 PM
Lucky9146   Have a modified RX7 Oil Cooler that came with th...   Aug 3 2015, 01:21 PM
lonewolfe   [quote name='screenguy914' post='2218202' date='A...   Aug 3 2015, 02:33 PM
Lucky9146   I have this same oil cooler but it's not insta...   Aug 3 2015, 03:36 PM
lonewolfe   I have this same oil cooler but it's not inst...   Aug 3 2015, 03:40 PM
Lucky9146   Yes I have pictures of the fabricated frame and fa...   Aug 3 2015, 03:50 PM
'73-914kid   I concur. I was always told with oil coolers, ...   Aug 3 2015, 03:11 PM
rhodyguy   You might want to cushion the line where it passes...   Aug 3 2015, 06:04 PM
Lucky9146   Thanks those are actually old pics from PO that ...   Aug 3 2015, 06:26 PM
gms   here you go   Aug 6 2015, 09:23 AM
Lucky9146   here you go Glen, thanks for the picture of th...   Aug 6 2015, 11:31 AM
McMark   If the thermostat has been gutted, you can flow th...   Aug 6 2015, 09:26 AM
jcd914   If memory serves me, there are 4 rows in one direc...   Aug 6 2015, 10:15 AM
gms   As Mark said, if you removed the thermostat it doe...   Aug 7 2015, 07:46 AM
Mark Henry   Although this sounds logical, I doubt it really ...   Aug 7 2015, 10:54 AM
rgalla9146   Thank you Glen for posting the factory diagram. ...   Aug 7 2015, 05:04 PM
lonewolfe   Perhaps the thermostat temperature setting is in t...   Aug 7 2015, 05:48 PM
- Lo-Fi Version Time is now: 14th April 2025 - 02:48 AM
