Cooling RPM, Oil temp Vs RPM |
DavidSweden |
Aug 14 2015, 03:30 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I have got my engine back together and running after 2 dropped valve seats.
I am keen to keep the heads cool, I think I read something on this forum about keeping the engine revs about 3500 to provide adequate cooling even if this means driving in 4th gear to keep the revs up. What to members advise? |
Big Len |
Aug 14 2015, 03:51 PM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
Is the motor stock is probably the first question?
DavidSweden |
Aug 14 2015, 03:57 PM
porschetub |
Aug 14 2015, 04:43 PM
Advanced Member Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Is the motor stock is probably the first question? Yes stock 2.0 Correct assembly of the motors cooling tins(no gaps),clean oil cooler,good engine compartment seals and plug seals,a clean motor,a good tune-up (using the right plugs),timing ,rocker clearance etc etc,all add if to make an engine run cool enough. No air-cooled engine likes to be "lugged" so this method would have its merits if you suspect overheating or are driving with the oil temp gauge,how hot is the summer in Sweden ??,cheers. |
Lo-Fi Version | Time is now: 20th June 2024 - 11:12 PM |
