b.stirbu |
1974 daily driver ![]() Group: Members Posts: 27 Joined: 14-June 15 From: Netherlands Member No.: 18,848 Region Association: Europe ![]() |
Dear 914ers,
I'm quite in a pickle with my 914 1.7. The engine sometimes starts sometimes not (usually after it started, ran 5-10 seconds and then stopped and I couldn't manage to start it again). Messing arround in the engine compartment I accidentally unplugged the cyl 4 fuel injector and surprise the engine started and idled low. Tried again one, two, three times and he started succesfully, but as soon as I plug back the cyl 4 injector cable does not want to start again... What's wrong here? (the injector not, because I've swapped 3 with 4 and I still had the same problem). According to the attached current flow cyl 4 injector is in series with the cold start valve and the thermoswitch for the cold start valve.. Am I looking at the right diagram? I also don't know where current track 102 comes from. Also very interesting is that I removed the injectors 3 and 4 and placed them in two cups to see if they work, and I could start the engine in two cylinders (although the cyl 4 injector plug was connected) Cheers, Bogdan Attached thumbnail(s) ![]() |
b.stirbu |
Hij doet het!!!
The little beast starts. Ha ha! But! as always... there is always a but, it idles around 3000rpm....niet goed.. I've unplugged the AAR suction from the air intake and placed my finger on the hose...the rpm drops to 1500....and it feels like a 2000w vacuum cleaner... Is that normal? |
Lo-Fi Version | Time is now: 26th June 2024 - 09:28 AM |
