Wanted, wheel spacers |
Old Yella |
Aug 21 2015, 07:52 PM
Old Yella Group: Members Posts: 158 Joined: 2-July 13 From: Canberra Australia Member No.: 16,086 Region Association: Southwest Region |
Hi
My tyres rub on the inner wheel wells I think I need some spacers. Anyone got any for 4 lug hubs. Tell me what you have. Thanks |
euro911 |
Aug 22 2015, 02:06 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
... Ahhh, are you talking about the fronts?Tyres are great just rubs on inner front wheel well at full lock. If so, how much do they rub? Your wheels are designed for the 914, but yes, they weren't really designed for too wide of a tire. 195's shouldn't rub, but not all 195 tires are the same. Check to see how much further you can turn the wheel after they start rubbing (a static test with the front of the car jacked-up, obviously). I run 7mm spacers on my front hubs and 38mm long bolts, but I'm running ATS Classics that have less back-spacing than your Mahles. Try different thickness test spacers to see how much you need to cure the problem ... you can make them from 1/4", 3/8" and 1/2" plywood for testing purposes, then purchase nice billet spacers in the thickness you require (and longer lug bolts as needed). (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:20 PM |
